ITR stock longblock on Boost???
ITR stock longblock on Boost??? UPDATE
Going to boost my stock long block ITR soon.(waiting on more parts)
Right now as is it makes anywhere from 198whp to 204whp(N/a bolt-ons and tuned)depending on which dyno and weather conditions.
I'm hoping to make around 300whp when its all done. At the end of the day I just want to make more power an still be reliable being this is my daily driver.
Here's a little run down of the car and current parts I have.
92 civic hatchback
98spec ITR longblock
Usdm itr tranny with LSD
Hondata S300
68mm Professional products throttle body
Speed factory 4bar map sensor
FIC injectors 525cc
Fuel lab fpr
255 walbro
Tail 38mm MVS
Tail BOV
Boost solenoid
PTE 5431E t3 .63ar
Treadstone T8 intercooler
Straightline motorsports IC pipping
Straightline motorsports custom Ramhorn Exhuast manifold a/c compatible
Straightline motorsports custom Downpipe(2.5"-3")
Strightline motorsports custom dumptube
Turbo blanket
DEI heatwrap
car was tuned on 93oct and on wastegate(8.7psi spring) no boost controller for now.
92 civic hatchback
Hondata S300
FIC injectors 525cc
Fuel lab fpr
255 walbro
Tail 38mm MVS
Tail BOV
Boost solenoid
PTE 5431E t3 .63ar
Turbo blanket
DEI heatwrap
Re: ITR stock longblock on Boost???
on the stock block with a cometic headgasket to lower the compression i made 300-350 whp on 7-11psi for at least 5 years...turbo was about the same size as well. make sure you get a good tuner for your hondata setup and you should have a blast with it..
Turbogixxertunning will be taking care of the tune here in south Florida.
i never understood why people want to boost an itr. it was build for high rev, high comp for a reason. if your just trying to go boost, just do an ls, or a gsr..
Who is Mr Robot?
high compression turbo motors make more power everywhere, on and off boost. muckman was making ridiculous numbers on his 14:1 e85 build
I plan on building a motor later so I figured why not eg this out the way.
It's what I have at the moment so why not use it!
I had a similar set up stock us Itr block,
I was on e85 with 1000 injectors on 1 bar I made about 400.
If you can if get a bigger injectors and run e85
My .02 is don't run a cosmetic HG oem is best
The whole hi-comp all motor and low-comp boost unwritten rule set needs to die already. Like already stated hi-comp + boost makes power through out the WHOLE powerband just need a good TUNER and/or E85.
Man U FTW
Man U FTW
I love my boosted R set-up. I have had it together for a year now on street/strip duty. I am making about 300whp 260wtq and it runs really strong. I was trapping 94mph in the 1/8th last night @2400 lbs and high altitude.
my opinion precisely. the head flows best and as long as you dont push it too hard its a great start...and high compression + boost isnt really new at this point..
Thanks
You can still turbo it no problem you will just have to run better fuel. If you have E85 in your area your golden.
Not bad, best I ever did N/A was a 8.88 @80mph. I raced my car for 2 years N/A and pulled 1.93-2.04 60 ft's on slicks. After the turbo your car will be a whole new animal. First time I ran mine after the turbo I banged off the anti-lag for a couple seconds and all of the sudden could pull 1.70 60 's and ap 94mph. You better work on traction cause banging off the limiter in first due to traction problems can severely shorten the life of your engine.
