ITR cams worth it on a low boost
Old Sep 13, 2005 | 03:15 PM
urbansi's Avatar
Default ITR cams worth it on a low boost
Well i will be picking up some ITR cams tonight and was just thinking it over before i pay for them, if it would be worth spending the money on them when i am only boosting like 10psi or so. i plan on raising the boost in the future but am just wondering if they are worth the money for a low boost setting.
motor is a GReddy(18g) turbocharged b16a2
thanks guys
Old Sep 13, 2005 | 04:34 PM
urbansi's Avatar
Default Re: ITR cams worth it on a low boost (urbansi)
ttt
Old Sep 13, 2005 | 05:18 PM
crx4life2002's Avatar
yeah if u had gsr cams I would say no but I would do it
Old Sep 15, 2005 | 09:48 PM
underb00steg6's Avatar
that's a good question ..i would like to know also....
Old Sep 15, 2005 | 09:55 PM
AspectIndustries's Avatar
Default Re: ITR cams worth it on a low boost (underb00steg6)
Get GSR cams, cheaper.. Save the money for other mods.
Old Sep 16, 2005 | 05:22 AM
urbansi's Avatar
Default Re: ITR cams worth it on a low boost (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">Get GSR cams, cheaper.. Save the money for other mods. </TD></TR></TABLE>
CTR's are cheaper but i think i am getting a reasonable deal on the cams so once the person contacts me back i believe i am going to buy them, just want to know if anyone has dyno'd their car before and after with these cams on a low boost setting like in between 5 psi and 12 psi
Old Sep 16, 2005 | 05:33 AM
HiProfile's Avatar
Its hard to really say. You'd get nealy the same benifits from just turning boost up a bit. Slightly higher IAT's maybe and a bit of more lag, but the other cams would also move the powerband up (same effect as that lag) and require more tuning (low cam profile).
I'd look at it this way. If you're boosting in the best effeciency range (or higher) now, get the cams. If its lower than optimal effeciency, don't get the cams yet - just turn up the boost. If its lower than optimal now and you turn it up, you shouldn't see much of a diff in IAT temps. The only benifit I'm sure of is the sound - stock engagement of itr/ctr cams is loud. Finally drove my brother's ctr'd hatch, VTEC resonating under a bridge is killer.
d16z6ef
Apr 23, 2007 07:13 PM
motoman358
Jan 6, 2006 05:57 AM
spoonhatchblack
Dec 13, 2005 09:21 AM
Charlie Moua
Mar 31, 2003 08:30 AM
