itr cams w/ turbo?
Old 10-18-2006, 09:44 PM
the.hamburglar's Avatar
Default itr cams w/ turbo?
anyone using them? just wondering how much more of an advantage they would be over my gsr cams? what about a itr intake and gsr exhaust?
Old 10-19-2006, 01:45 AM
komat's Avatar
Default Re: itr cams w/ turbo? (the.hamburglar)
depending on your setup and power goal. it may be worth it.
im using them on my setup
Old 10-19-2006, 02:31 AM
Redline130's Avatar
I'm using CTR cams in my motor. I know they have to be better than using B16A cams.
Old 10-19-2006, 03:19 AM
sc4dr's Avatar
Default Re: itr cams w/ turbo? (Redline130)
Im using itr's on my gsr. Nice fat power curve all the way to my 8500 redline. I never dynoed with my gsr cams, so I dont know the difference.
Old 10-19-2006, 03:21 AM
Don't call it a comeback
Stunna BEN's Avatar
Default Re: itr cams w/ turbo? (sc4dr)
ITR cams for boost
Old 10-19-2006, 07:30 AM
Default Re: itr cams w/ turbo? (Stunna BEN)
58mm tb or 62 mm tb? noticable difference?
Old 10-19-2006, 07:48 AM
DRIVENRacing's Avatar
with boost, the bigger the CAM, the more power you will make.. just make sure if you go big cam, go stock size valve... skunk2 stage 3 NA cams here.. 740whp
Old 10-19-2006, 09:33 AM
EGUK's Avatar
Default Re: (adSPEED)
I was trying to swap my N/A Skunk2 stg 2's for standard ITR/CTR cams as I'm going boost now.
So your saying I'll be ok using them?
Anything else I need to consider when using them?
Old 10-19-2006, 09:35 AM
ATYPR's Avatar
Default Re: (EGUK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGUK &raquo;</TD></TR><TR><TD CLASS="quote">I was trying to swap my N/A Skunk2 stg 2's for standard ITR/CTR cams as I'm going boost now.
What manifold are you running?
BTW, I'm running ITR cams also.
Old 10-19-2006, 09:37 AM
476 whp / 323 tq @ 17 PSI
JDM turbo DC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">what about a itr intake and gsr exhaust?</TD></TR></TABLE>
definately run the ITR/CTR intake cam, theres no real difference between the GSR and ITR/CTR exhaust cam
Old 10-19-2006, 09:55 AM
Teglove2's Avatar
I got a ? for you adSpeed. We're in the process of building a 2020 ls/vtec fully built obviously with a Shearer fab divided t4 manifold and a gt42 and we were def looking into getting cams. The thing is that itr/ctr cams are so F*(&&% expensive that I'd rather buy aftermarket cuz they're cheaper!! I was looking at either skunk 2 or comps cams for this setup. Whats your opinion on that?
Thanks
Ryan
Old 10-19-2006, 12:18 PM
GS-R Civic's Avatar
I am also interested in the benifit of ctr intake cam with gsr exhaust. I am currently making 275whp now on 7psi on my jdm gsr stock motor.
I want to do:
ctr intake cam
blox intake manifold
cam gear tuning
maybe up the boost to 10
I know some of this is off topic, i just want to know about the cam if possible, Thanks!
Old 10-19-2006, 02:00 PM
Default Re: itr cams w/ turbo? (GS-R Civic)
i was wondering if the gsr exhaust with the itr intake would hold boost better. kind of like trapping it in the combustion chamber for just a little longer than the intake cam? any ideas? whatever is going to make the most power obviouly.
Old 10-19-2006, 02:59 PM
like i said before, gsr, itr, ctr cam will be alot easier to tune because itll make your power band alot more linear.. big cams are thirsty, little more dificult to tune, but you can also play with the overlap and as far as a big cam id say go with a skunk2 stage 2s for boost, and just dont run oversized valves with it... big displacement, stock size valve, make sure you measure your ptv clearance also with the big cam... but as far as a race car, and alot of power at a low boost level, RUN BIG CAMS.. SKUNK2
Old 10-19-2006, 04:17 PM
ok but what about using different intake and exhaust. i have 3 sets of cams. b16, gsr, itr. what is the best combo?
Old 10-19-2006, 05:15 PM
95dc2teg's Avatar
Default Re: (the.hamburglar)
Not to thread jack but I have a 95 integra gsr with 57trim t3/t4 turbo set at 7psi on a stock block. Would i benefit if i just bought an ITR intake camshaft and just dropped it in?
Old 10-19-2006, 05:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">ok but what about using different intake and exhaust. i have 3 sets of cams. b16, gsr, itr. what is the best combo?</TD></TR></TABLE>
go with the ITR set, the ITR intake cam for sure and either the GSR or ITR exhaust cam
Old 10-19-2006, 06:05 PM
GS-R Civic's Avatar
Default Re: (95dc2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg &raquo;</TD></TR><TR><TD CLASS="quote">Not to thread jack but I have a 95 integra gsr with 57trim t3/t4 turbo set at 7psi on a stock block. Would i benefit if i just bought an ITR intake camshaft and just dropped it in?</TD></TR></TABLE>
thats pretty much my question! from what i have been reading it will help a little, but nothing crazy, but then its all in the tune!
Old 10-20-2006, 08:04 AM
EGUK's Avatar
Default Re: (FUCATYPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FUCATYPR &raquo;</TD></TR><TR><TD CLASS="quote">
BTW, I'm running ITR cams also. </TD></TR></TABLE>
I'm running BBK intake with 70mm T/B?
Old 10-20-2006, 08:07 AM
perfect, then run big cam
Old 10-20-2006, 08:18 AM
EGUK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED &raquo;</TD></TR><TR><TD CLASS="quote">perfect, then run big cam</TD></TR></TABLE>
Skunk2's Stg2's it is then.
Old 10-20-2006, 08:30 AM
if u dont mind me asking, what is gonna be your turbo setup??
Old 10-20-2006, 08:33 AM
Default Re: (EGUK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-R Civic &raquo;</TD></TR><TR><TD CLASS="quote">I am also interested in the benifit of ctr intake cam with gsr exhaust. I am currently making 275whp now on 7psi on my jdm gsr stock motor.
I want to do:
ctr intake cam
cam gear tuning
I know some of this is off topic, i just want to know about the cam if possible, Thanks!</TD></TR></TABLE>
do not waste your money on a blox intake manifold, if your gonna get a im get victor x, or something bigger.. dont do skunk2 or blox, , dont wory about cam gear tuning unless you go big cams, up the boost to 10 ish youll be 300 plus easily depending on what turbo your gonna run.. gl
Old 10-20-2006, 08:35 AM
EGUK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED &raquo;</TD></TR><TR><TD CLASS="quote">if u dont mind me asking, what is gonna be your turbo setup??</TD></TR></TABLE>
I'm using a Peakboost topmount with 4in D/P with GT30R turbo.
Old 10-20-2006, 08:39 AM
3076r??
Quick Reply: itr cams w/ turbo?
