is300 supercharger install help (fuel problems)
Old Dec 21, 2003 | 09:52 PM
garados's Avatar
Default is300 supercharger install help (fuel problems)
Alright, I'm having problems with the fuel lines. There is an additional injector that my brother and I installed, and it's fuel line fittings are leaking. We torqued the fittings down about one to one and a half turns past hand tight. Teflon tape was used, but it still leaks. Any suggestions? The fittings are brass, so I don't think they should be torqued down too much. Should we use more teflon? Thanks for any advice.
Old Dec 21, 2003 | 10:00 PM
youngkow's Avatar
Default Re: is300 supercharger install help (garados)
What kind of teflon are you using? Are you using the fuel proof pink teflon? I think you should tighten in more that 1 1/2 turn past hand tight.
Old Dec 21, 2003 | 10:17 PM
garados's Avatar
Default Re: is300 supercharger install help (youngkow)
using the white teflon tape. Is the pink tape available at hardware stores? Thanks for the quick reply
zippakilla
Feb 17, 2009 10:26 PM
anothersickhatch
Nov 7, 2007 05:20 PM
EJ1 wilcox
Apr 17, 2005 05:20 PM
ludelvr
Apr 27, 2002 09:40 PM
Mr. Vapor
Sep 26, 2001 03:08 PM
