Iron sleeves for $46 a peice
Guest
Posts: n/a
Re: Iron sleeves for $46 a peice (BoostedsiR)
I seen those ads before. They are usually in the back of sc, ss, turbo... That's where im gonna order my piston+rods from
Re: Iron sleeves for $46 a peice (TTWS6.)
Most likely these are stock steel liners. Used as replacements. I highly doubt these are the sleeves you are thinking of.
Re: Iron sleeves for $46 a peice (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic »</TD></TR><TR><TD CLASS="quote">Most likely these are stock steel liners. Used as replacements. I highly doubt these are the sleeves you are thinking of.</TD></TR></TABLE>
still though, wouldn't these be better than stock sleeves?
Re: Iron sleeves for $46 a peice (shermanyang)
No, these are most likely a stock sleeve replacement. Basically if stock were out of round too far or heavily damaged in some other way. But hey, these could be the real deal......who knows. A pic would be nice.
Darton sells the same sleeves, if they are replacements, along with the race sleeves. I think i was quoted at 36 a sleeve. But the machine shop will still charge same price so you might as well save up 400 dollars and get it done with the race sleeves.
I am a bad person
Re: Iron sleeves for $46 a peice (ichibanjap)
I sell ARI sleeves which are a ductile iron straight sleeve for 42 each. we have used them in our h22 car and made 689whp and the sleeves have held up. you just have to make sure they are installed correctly. for the most part a ductile iron sleeve is a sleeve.
I run the same sleeves in my motor and boost 25 psi and it held up. We do these sleeves, open deck dartons, aebs, close deck dartons. We are aebs sleeves dealer.
Guest
Posts: n/a
Re: Iron sleeves for $46 a peice (MotorMatrix.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com »</TD></TR><TR><TD CLASS="quote">I sell ARI sleeves which are a ductile iron straight sleeve for 42 each. we have used them in our h22 car and made 689whp and the sleeves have held up. you just have to make sure they are installed correctly. for the most part a ductile iron sleeve is a sleeve.</TD></TR></TABLE>
arte these closed deck sleevs and do you have them in a big bore for a b16?
lemongreenhatch
103
11-16-2004 05:37 PM
