Intsalling a Turbo setup on a D16y8 Problems!
Old Dec 31, 2006 | 12:00 PM
Frost7177's Avatar
Default Intsalling a Turbo setup on a D16y8 Problems!
Where do I tap into for the oil pressure feed line I was looking at the spot on the vtec near the manifold. Can I tap into anywhere else?
Old Dec 31, 2006 | 12:03 PM
booscivic's Avatar
use brass fitting and tap from the oil pressure sensor
Old Dec 31, 2006 | 12:08 PM
Frost7177's Avatar
Default Re: (booscivic)
Where is the oil pressure sensor in this car located?
Old Dec 31, 2006 | 12:24 PM
igo4bmx's Avatar
back of block near the oil filter is the oil sensor.
you need to run a T, or you can buy an oil filter sandwich plate with npt ports on it, which is what I did
cambopheonix56
Aug 23, 2006 04:36 PM
MBlake55
May 3, 2006 06:19 AM
JforJonathan
Apr 17, 2005 10:47 AM
ricin97civic
May 3, 2002 11:57 AM
