yet another b18 turbo...
Old Nov 19, 2003 | 07:11 PM
scatuli's Avatar
Default yet another b18 turbo...
but it doent seem to pull hard i have 2.5 in piping all the way through uberdata with a tuned map and it doesnt feel like it pulls hard it is at 10 psi with a t3t4 57t .63 ar fmax mani and a 2.5 in exhaust
at first i was too lean then i got uberdata and it is at .90 ish according to a volt meter i know its not accurate but its all i have for now
any things i should check out or things i should change?
thanks
Old Nov 19, 2003 | 07:14 PM
B16OnTop's Avatar
Default Re: yet another b18 turbo... (scatuli)
just a guess but i think it might be your 2.5 inch exhaust, isnt that a little restrictive for 10psi
Old Nov 19, 2003 | 07:17 PM
scatuli's Avatar
Default Re: yet another b18 turbo... (B16OnTop)
possible but i would think it would pull harder still?
i might hook up a adjustable fuel pressure regulator and see i that does anything after i bump it up a little
Old Nov 19, 2003 | 07:25 PM
shermanyang's Avatar
dyno is your friend. that's the only way you'll ever get an accurate reading of what is happening.
and i don't believe it's your exhaust because i've got a 2.25" exhaust and the sucker still pulls.
Old Nov 19, 2003 | 09:13 PM
PHiZ's Avatar
Default Re: yet another b18 turbo... (shermanyang)
2.5 inch exhaust is rumored to be good up to 250 HP...
-PHiZ
Old Nov 20, 2003 | 03:19 AM
scatuli's Avatar
Default Re: yet another b18 turbo... (PHiZ)
k thanks i am going to do a compression test then i am going to go to the dyno
and even though my dp is 2.5 in and i got a 3 exhaust after that would it still flow 3
becuase someone told me that it will only flow as much as the smaller pipe
Old Nov 20, 2003 | 03:46 AM
scatuli's Avatar
by the way about what should the numbers be on a b18a1 i know they should be about 15 percent of each other but how high for the number? like 170?
and phiz what are you holding in your hand?
Old Nov 20, 2003 | 04:56 AM
Rah Rah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">dyno is your friend. that's the only way you'll ever get an accurate reading of what is happening.
and i don't believe it's your exhaust because i've got a 2.25" exhaust and the sucker still pulls.</TD></TR></TABLE>
I agree. I have a 60mm exhaust (2.36 inch) and it's fine. If you're not making over 300 whp a 2.5 inch is fine.
Modified by Rah Rah at 11:40 AM 11/20/2003
Modified by Rah Rah at 11:41 AM 11/20/2003
Old Nov 20, 2003 | 06:01 AM
b16ahybrid's Avatar
Exactly...
Old Nov 20, 2003 | 06:49 AM
PHiZ's Avatar
Default Re: yet another b18 turbo... (b16ahybrid)
Avatar is a charge pipe and blitz blow off valve.
If the DP is 2.5 inches, and you go to a 3 inch exhaust, What you say about the smallested diamater being a choke point does sound reasonable or true.
Howeve I've heard ppl argue that the hot gas is going to want to expand when reaching the 3in portion, also a little choked off diamater helps you spool quicker.
Decreasing diamater sacrifices volumetric flow for velocity...
-PHiZ
Old Nov 20, 2003 | 07:51 AM
quikB18B's Avatar
Its not your exhuast, it seems your car needs hit the dyno to find the porblem. Remember fuel is everythnig is a turbo setup.
Old Nov 20, 2003 | 01:54 PM
scatuli's Avatar
Default Re: yet another b18 turbo... (quikB18B)
hey i just did a comp test and it was about 150 all the way across
i think i am going to hit the dyno sometime soon hopefully
thanks
Old Nov 20, 2003 | 02:01 PM
Boltz's Avatar
i think there is an underlying problem. Even rich *** fmu setups pull hard, i figure with that boost on that motor with a decent turbo like that he should feel it pulling a lot quicker do a compression/leakdown
Old Nov 20, 2003 | 02:26 PM
DIRep972's Avatar
Smarter than you
uberdata maps are not tuned maps. You need dyno time.
Old Nov 21, 2003 | 03:57 AM
scatuli's Avatar
Default Re: yet another b18 turbo... (DIRep972)
i have goldjungs tuned map
and i am gonna do a leakdown this weekend hopefully
Old Nov 21, 2003 | 05:12 AM
Tinker219's Avatar
ya, but every engine is different go to the dyno, put down 250whp, be happy
kou-integra98
Oct 11, 2013 07:20 AM
rudebwoy
Oct 27, 2007 05:33 AM
GokuSSJ4
29
Aug 3, 2003 05:23 PM
turbo craig
Jul 29, 2002 11:26 PM
b18cTurbo
Feb 26, 2002 06:41 PM
