Intercoolers and performance a must read
Old Mar 24, 2004 | 08:13 AM
Bontke's Avatar
Default Intercoolers and performance a must read
I ran across a page about the science of intercoolers. This website had so much info about intercoolers and their flow. This is a must read if you want the most out of your turbo and intercooler.
http://www.are.com.au/index.htm Look on the left cell of the page for a section called "Intercoolers a must read"
Old Mar 24, 2004 | 08:44 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Intercoolers and performance a must read (Bontke)
I must say, at a glance that article looks quite extensive and informative, havent had a chance to actually stop and read it tho... thanks!
Blaze
Old Mar 24, 2004 | 09:07 AM
Chillinit's Avatar
Default Re: Intercoolers and performance a must read (Blaze45)
nice site!!!
Old Mar 24, 2004 | 09:50 AM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: Intercoolers and performance a must read (Chillinit)
I took about 20 min and got the jist of it, good info, thanks for the link
Old Mar 24, 2004 | 10:49 AM
integraracing91's Avatar
Default Re: Intercoolers and performance a must read (preacherboy)
Cliffnotes needed
Old Mar 24, 2004 | 11:28 AM
Sinner's Avatar
great site, I must read for water intercoolers!
Old Mar 24, 2004 | 11:59 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (Sinner)
Something I found interesting:
"...because the outlet is in line on the other tank,- even worse!"
So inlet & outlet on the endtanks should NOT be in line with each other?
Old Mar 24, 2004 | 01:33 PM
project dc2's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Something I found interesting:
So inlet & outlet on the endtanks should NOT be in line with each other?</TD></TR></TABLE>
my idea is that the primary air will be " racist" against other tubes and take the most direct action instead of spreading out and utilizing all the tubes to clear.
the intercoolers with short verticle flow tubes are better design and a better choice than the traditional ones we use that go horizonal.
Old Mar 24, 2004 | 01:54 PM
SiRkid's Avatar
Default Re: (project dc2)
so whats better..bar and plate or tube and fin? hmmmmmm
Old Mar 24, 2004 | 02:10 PM
Default Re: (SiRkid)
i think bar n plate is better, the air has a more direct way of getting into the tubes whle tube and fin has a bevel around the edges which sends turbulance in the air going intot he tubes. at least tahts what i learned from corky bell heheh
Old Mar 24, 2004 | 02:19 PM
shortyz's Avatar
http://www.are.com.au/techtalk/intecoolersMR.htm
easier link
m R g S r
Welding / Fabrication
May 30, 2007 09:06 AM
96hb
Jan 6, 2004 01:01 PM
Solipsist
Jan 19, 2003 04:20 AM
IIIISTUMBLESIIII
May 22, 2002 08:34 AM
