Intercooler question
Old Mar 5, 2009 | 10:13 AM
bboysake's Avatar
Default Intercooler question
Does anybody know if I change out intercoolers, do I have to get a retune also?
Old Mar 5, 2009 | 10:23 AM
b20beast83's Avatar
Default Re: Intercooler question
should not if your iat tables are tuned
ask your tuner
Old Mar 5, 2009 | 12:22 PM
ll3o0sTeD's Avatar
nah i doubt it...i wouldnt worry about it to much...but i would ask your tuner to be on the safe side...
Old Mar 5, 2009 | 01:13 PM
Riake's Avatar
Depends on how drastic the efficiency of one is compared to the other.
Old Mar 6, 2009 | 09:46 AM
bboysake's Avatar
well the depth of my new intercooler is a bit deeper than my old one, probably about 1/2inch.
ask your tuner
thanks guys for your thoughts! I'll definitely ask him.
Old Mar 6, 2009 | 09:54 AM
SOHC®'s Avatar
I highly doubt it.
Unless the new cooler drastically lowers Intake Air Temps, which under extreme conditions may make your motor run lean
Old Mar 6, 2009 | 12:55 PM
HiProfile's Avatar
If you were maxing your current FMIC out, chances are yes. You can't exactly tune for a cooler IAT at full boost if your setup never experienced it.
You can also run at different turbo shaft speeds due to a lower (or higher) pressure drop. That will affect the turbo efficiency, as well as the turbine flow. No Honda ems has a compensation table for changes in exhaust backpressure...
B16Civic93
Apr 6, 2009 11:15 AM
high boosted rex
Jan 5, 2006 02:05 AM
91glassycrx
May 7, 2004 12:26 PM
boostn5Ghaba
Mar 4, 2002 11:46 AM
Arturbo
Nov 17, 2001 05:15 AM
