Intercooler piping size
Old Dec 30, 2003 | 11:36 PM
JM Performance's Avatar
Default Intercooler piping size
I know...I'm bored....I'm making a lot of dumb discusion posts, but....
Every major kit comes w/ 2.5" piping, some do 2.25" from the turbo to the IC.
Every book and decent autority says that for under 300hp ic piping should be kept around 2".
I've never seen anyone run 2" ic pipes (even though I probably will on my upcoming project)
Any thoughts? Bigger is better getting into peoples heads?
Old Dec 30, 2003 | 11:39 PM
Kwuaymaikrup's Avatar
Default Re: Intercooler piping size (00SilverLS)
The red hatch from GroundZero Motorsports runs 2 inch I believe. He is making over 500 whp on his setup. I personally am going to run 2.5 to match the outlet on my turbo as well as my throttlebody.
-Ryan
Old Dec 30, 2003 | 11:58 PM
martinscott's Avatar
Many aftermarket kits have a 2 inch pipe from the turbo to intercooler, then 2.25-2.5 from the ic to throtle body. This is often done to match the pipe diameter to throtle body. On many occasions, I have played with pipe sizing to either increase or decrease boost response which effects the power band slightly. Smaller the pipe, the better the response. the larger the pipe, the more flow it provides... but larger is not always better. Stick to 2-2.5 inch
Old Dec 31, 2003 | 12:00 AM
integlspwr2k's Avatar
Default Re: (martinscott)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martinscott &raquo;</TD></TR><TR><TD CLASS="quote">Many aftermarket kits have a 2 inch pipe from the turbo to intercooler, then 2.25-2.5 from the ic to throtle body. This is often done to match the pipe diameter to throtle body. On many occasions, I have played with pipe sizing to either increase or decrease boost response which effects the power band slightly. Smaller the pipe, the better the response. the larger the pipe, the more flow it provides... but larger is not always better. Stick to 2-2.5 inch</TD></TR></TABLE>
oh my god so your telling me the 3" pipes i am currently using on my greddy turbo kit @ 7psi too big?
Old Dec 31, 2003 | 12:13 AM
Default Re: (integlspwr2k)
YOUR RUNNING 3" PIPES? OMG YOUR GUNNA CHOKE YOUR ENGINE!!! better install some 6" pipes asap
Old Dec 31, 2003 | 12:16 AM
You got to be kidding me?only 3 inch? Why are you using such small pipes. You need to upgrade to 4 inch. Then you can make some real power!! I think 6 inch pipes might be over kill unless your aiming for 110whp. any less than that go with the 4 inch!!
Old Dec 31, 2003 | 12:33 AM
lazerus's Avatar
you're just full of them tonight!!!!!!!!!!!!
jp
In my opinion, i think optimum intercooler piping size, the OD of the outlet of the compressor should match the OD of the charge pipe to the intercooler, and from the IC to the TB it should step up 1/4 - 1/2 inch in size, and then open up near the throttle body to match its size...
Old Jan 1, 2004 | 08:02 AM
delslowh23's Avatar
Default Re: (lazerus)
that what i do
killablaze
Dec 1, 2005 04:18 PM
the.hamburglar
Jun 26, 2005 11:56 PM
SIReg9
Jul 21, 2003 01:07 PM
SSS2000
Jul 3, 2003 05:12 AM
jthelman
Feb 15, 2003 11:32 PM
