integra turbo recomendations (fuel setup)
From: MY GIRLFRIENDS MOMS HOUSE, NEW BERLIN, WI, USA
I own a 94 gsr with a drag gen 3 turbo kit (2.5 inch exhaust all the way back, t3/t40E turbo) . The engine is getting sleeved (81.5 mm oversize je pistons with 8.5:1 comp., eagle rods) I am replacig the crank bearings, oil pump and water pump. No head work is done at this time. The car has a few highway miles (not that is matters except for the stock head). Anyways, it was wondering what boost i should run. I was thinking about somewhere between 15-18 psi. The fuel system is reguated by V-AFC with 450cc DSM injectors/resistor box from a
89 integ, vortech FMU, and walbo 255 high pressure fuel pump. What are some suggestions as far as boost, V-AFC settings with FMU installed, or anything else that comes to mind. Thanks
