weird problem (if it is a problem)
Old Jun 17, 2004 | 06:20 AM
bluebomb's Avatar
Default weird problem (if it is a problem)
hey,
lately, when i start my car in the morning (or when its cold) the car has a hard time starting, and also, it vibrates like crazy. Almost sounds like it runs on 3 cyliders, BUT THEN, after about 5-10 seconds, it runs normal, but refs high (about 2 grand) till the car warms up. I have a 2001 Integra LS engine, running on a OBD1 Integra LS chipped ECU.
Thanks for your help in advanced!
Johan Broersma
Old Jun 17, 2004 | 07:42 AM
JimBlake's Avatar
Default Re: weird problem (bluebomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebomb &raquo;</TD></TR><TR><TD CLASS="quote">... Almost sounds like it runs on 3 cyliders, BUT THEN, after about 5-10 seconds, it runs normal...</TD></TR></TABLE>Maybe it IS on 3 cylinders. Have you checked your plug wires & cap for arcing? Last time I had a plug wire with insulation going bad, that's how it behaved.
Look for arcing with a cold engine in the dark.
Old Jun 17, 2004 | 08:09 AM
kablamo's Avatar
i have EXACTLY the same problem.
i've had it on my teg, i've had it on my lude. I've done tuneups to no avail...
I just live with it, fact is it only happens once a month if that, usually when it's cool (not necessarily though).
it wasn't my:
-spark plugs
-wires
-dist cap (rotor)
-air filter
-fuel filter
-coolant temp sensor
no engine codes in both cases. intermittent problems suck.
kaiba
Sep 8, 2005 03:25 PM
SpoolinEK9
Jul 12, 2005 02:27 PM
B18GSR
Jun 6, 2005 07:46 AM
cr00klyn718
Aug 20, 2004 06:20 PM
DanishR
Jul 28, 2003 01:19 PM
