intake manifold swap, no boost
Old Apr 15, 2008 | 05:35 PM
vrafa89's Avatar
Default intake manifold swap, no boost
i have a 98 civic lx with a d16y7 non vtec.
i just put a turbo in it and the car ran great untill i got a d16y8 intake manifold from a 99 civic ex vtec.
now my car will not boost, maybe only 5psi or less but thats it.
The stock manifold from my car is the one that the throttle body faces UP.
Any ideas please???
Old Apr 15, 2008 | 08:03 PM
95dc2teg's Avatar
Default Re: intake manifold swap, no boost (vrafa89)
you have a boost leak somewhere check for vacuum leaks
Old Apr 18, 2008 | 07:02 PM
vrafa89's Avatar
Default Re: intake manifold swap, no boost (95dc2teg)
hey... thank you for the answer, i looked for the vacuum leak, sprayed all the lines and stuff but no vaccum leak.
im gonna try putting the old one back on to see what happens...
thank you
Old Apr 18, 2008 | 08:30 PM
93CX's Avatar
Did you use fresh gaskets? It has to be a leak somewhere
Old Apr 21, 2008 | 07:49 AM
94b16teg's Avatar
Did you spray it around the area where the head meets the manifold? If not try it I used a 99 y8 manifold and had a high idle. After I pulled it apart i found these little holes above the injectors that werent on my old manifold and it was leaking. I used jb weld and plugged them and it has held up fine.
ballisticej1
Dec 22, 2009 02:00 PM
oodie
Sep 11, 2009 08:51 PM
civicnar
Mar 17, 2005 09:39 PM
X-Mazda 3 Racer
May 21, 2003 08:40 PM
