intake manifold or cams
Old Nov 30, 2020 | 11:03 AM
SlwGsr's Avatar
Default intake manifold or cams
well im trying to decide the next mod on my built lsV setup. not sure to go intake manifold like victor x or new cams and port the stock intake manny for now. need some opinions.
Old Nov 30, 2020 | 12:28 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
Default Re: intake manifold or cams
‘what’s done to the car? That’s the biggest thing that will decide what is best next.
Old Dec 1, 2020 | 03:30 AM
SlwGsr's Avatar
my bad its a lsVtec with pistons/rods/springs/retainers/gsr cams/b16 head/ top mount 35r making 500hp. has a stock b16 intake manifold and nothing is ported. was thinking victor x to open up the top end so when I get cams it will make that much more a difference. or since my goal is about 600-650 for now until i get a better block to just go cams and port the stock manifold to tb and head. then when i get the new block ill get the head ported. after that ill need to worry about trans upgrades before more power.
Old Dec 1, 2020 | 04:52 AM
ls joker's Avatar
Loved
with the turbo, turbo manifold, and your whp goal, i think the victor x intake manifold would be better beneficial for your build as it is now. I agree you, if you got cams now your intake manifold could and most likely would become a bottleneck
Old Dec 1, 2020 | 05:35 PM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
I swapped to the victorX more for the extra room under the hood but it does flow nice. You need 3 things at once to be beneficial....1.....I would get cams which would bump your power curve to a higher range ....2.... get a throttle body and intake manifold upgrade ......3...harmonic balancer . You need that combo of items to see the full benefits of each component
Old Dec 17, 2020 | 11:10 AM
Balor_Gr's Avatar
Imo no manifold will give results compared to what cams like GSC / kelford 176t / skunk2 pro1 will give as extra power...
Old Dec 17, 2020 | 11:20 AM
fotis2000's Avatar
Pro 1 is the way to go
Old Dec 17, 2020 | 07:11 PM
TheShodan's Avatar
Moderator
Depends upon the size of the turbocharger and the purpose. Pro1 is an option, but not the only option depending upon the use. But I do think that camshafts will help more than any intake manifold. You also need to state your purpose of the car. Just describing the setup gives too many loose interpretations.
Old Dec 23, 2020 | 04:09 AM
SlwGsr's Avatar
I use the car for strip only as its not registered to drive on the street. I do plan to keep it able to be driven on the street in case one day I decide to drive it to a meet or something. I found a pretty good deal on a victor x and put a 70mm tb on it and port matched everything and it is currently waiting for a dyno session. I opted out of getting cams atm because the tuner said gsr cams are more then enough until I am wanting more power. I will report back with the results when it happens in January, Thanks
Edit, its on a 35r as previously stated
Old Dec 23, 2020 | 07:48 AM
TheShodan's Avatar
Moderator
In that case, honestly, I'd still say the camshafts. You're going to get a few ponies in the top end from the Intake manifold, but the camshafts will do more for you. Eventually, you'd need both anyway, but at least with the camshafts, you only have to retune with those. Not with the Intake manifold.
Good luck with whichever you decide.
Old Jan 19, 2021 | 09:01 AM
B and B's Avatar
Loved
Community Favorite
Did you make it back to dyno yet?
golf-mk3
Aug 25, 2010 04:51 PM
ls_bitik
Nov 25, 2007 10:30 PM
04DOHC
10
Aug 2, 2006 01:40 PM
99hondacura
Jul 2, 2006 12:55 AM
DeviousLude
Dec 21, 2005 08:54 AM
