Intake manifold?
Old Sep 16, 2008 | 03:56 AM
TurboEK9Coupe's Avatar
Default Intake manifold?
I am wanting to upgrade my AEBS intake to an Edelbrock Victor X one. Also I plan on upgrading to a larger throttle body. My question is would a 70mm Skunk2 throttle body fit on the Edelbrock manifold? And how much of a gain would I see switching manifolds? My set-up is Peakboost top mount w/ 66mm turbo, built and sleeved block, crower stage II cams and valve train, and 9 to 1 compression.
Old Sep 16, 2008 | 05:08 AM
Turbo-charged's Avatar
Default Re: Intake manifold? (TurboEK9Coupe)
the TB will fit, you will just have to port it to the larger opening. i forget the opening of the victorx manifold, i think its 65 or 68.
i'd stay away from the skunk TB's as they stick like crazy and are really annoying. should see some decent gains from the IM
Old Sep 16, 2008 | 05:20 AM
Default Re: Intake manifold? (Turbo-charged)
What throttle body would you reccomend? Would a 70mm be a good choice or should I go with a 68mm? Thanks
Steeve_Civic
Jan 19, 2014 04:28 AM
shahriar35
Jan 31, 2010 12:13 AM
jnasty
Nov 16, 2006 03:24 PM
