Instrument that can read direct from a MAF sensor?
Old Jan 30, 2005 | 10:21 AM
MidShipCivic's Avatar
Default Instrument that can read direct from a MAF sensor?
I need to take air flow rate readings from the charge pipes so I can datalog them, I'm trying to find something to read air flow rate, I was thinking if I can use a maf and read off of it.
Basically I need something that can datalog airflow airtemp and engine rpm.
Old Jan 30, 2005 | 10:34 AM
toolowsol's Avatar
Default Re: Instrument that can read direct from a MAF sensor? (MidShipCivic)
The MAF sensor will output a 0-5v signal, The type of maf will determan what voltages correspond to what flow rates. Once you get a MAF sensor and determan the equation for it, you can datalogging with any number of the datalogging softwares on the market.
Old Jan 30, 2005 | 10:42 AM
Default Re: Instrument that can read direct from a MAF sensor? (toolowsol)
Thanks.
Anyone know a good datalogger that uses MAF?
( I don't want nothing cheap) I'm searching.
holmesnmanny
Honda Civic (2006 - 2015)
Mar 16, 2017 12:41 AM
MantisX
Audio / Security / Video
Apr 7, 2010 07:40 AM
AnAccordIsForever
Nov 27, 2007 03:23 PM
iwantspeed
Honda Civic (2001 - 2005)
11
Jan 5, 2007 07:20 PM
sleeperaccordv6
Jun 26, 2002 10:31 AM
