Installing Greddy EGT probe
Old Jun 9, 2004 | 06:34 PM
Sohc Driver's Avatar
Default Installing Greddy EGT probe
I need help on installing my egt probe..as you can see from the pics..I have egt probe sensor, two fittings, and the ring.
My question is...how do i get the probe to stay in the fitting? Isn't there suppose to be something there to hold the sensor in place?
When I have everythign assembled seen in the picture below:
I can easily pull the sensor out seen in this picture:
How do I keep the probe in place?
Khoi
Old Jun 9, 2004 | 06:51 PM
gritsak's Avatar
you put the nut on the sensor backwards first..so the threads are facing down..then the small crush washer (on the far right of your top pic) then screw it into the fitting...adjust the length of the probe so it sticks down around half way into the pipe...when you tighten the sleeved nut..it will put pressure on the washer in between and make it hold the probe in place..
Old Jun 9, 2004 | 07:05 PM
Default Re: (gritsak)
Oh wow...it worked! Thanks for the help..all I had to do was screw it down really tight..and some how it put pressure on the probe...
Thanks!!
Khoi
b20forlife
Dec 30, 2009 03:18 PM
Sohc Driver
Jun 10, 2004 04:12 PM
milf H U N T E R
May 31, 2003 09:45 AM
