install help gt30/70
my turbo is to big for install , turbocharger a/r 70 side to near on motor block and contact motor.
i need 16,5 cm side.
what for a turbo manifold i need??? must more to front side.
and yes i need a better turbo manifold for this project.
pictures info.
http://img688.imageshack.us/img688/8450/dsc00005sc.jpg
http://img688.imageshack.us/i/dsc00005sc.jpg/
http://img690.imageshack.us/img690/598/uiiiiik.png
http://img690.imageshack.us/i/uiiiiik.png/
mfg..
pictures info.
mfg..
lets start with what car and which engine? will you be running the compressor on the passenger side (AC compatible) or on the drivers side? the .70a/r doesnt tell us much about size. do you know which compressor cover you have e, s?
b16a1 ef9/ee9
i will install the turbocharger downpipe driver site front
and air filter the batterie site .
donepipe site is the same like old charger ,then i will use old downpipe again.
the a/r site is to big ,no way to install this with old low buget xs manifold.
i need neu and better manifold.
http://img535.imageshack.us/i/p2404101546.jpg/
this is god
http://www.speedfactoryracing.net/st...products_id=83
this is god
you should be able to run a spoolin performance log mani or any ramhorn should work
http://www.spoolinperformance.com/sp...fold-p-58.html
if you change your turbo manifold you most likely will need a new downpipe or modifications to your current one. its recommended to buy a mani/downpipe as a set to make sure they fit properly together.
as far as the SPA top mount that you linked. here is some info on that manifold
https://honda-tech.com/forums/showth...&highlight=spa
mmhh this manifold ??
the turbocharger is to high with this manifold ,can i open and close anfer install the cover, and wenn is temp.high this cover paint gona smelts like ice in the soneshine
