Install help
Old May 27, 2004 | 06:15 PM
etrauty's Avatar
Default Install help
I have been working on installing a drag 3 turbo kit on my 2000 Honda civic. Its about 80% complete, untill the rest arrives. I used to have a short ram intake , which i have since removed to install the charge pipe. My question is In the ram intake there used to be a hole for the air temp sensor, Where whould that sensor go now, There is no place for it on any of the turbo kits pipes. One more Questions where would be a good place to tap in the vacumm source for the bov and the wastegate. Any help or advice would be appreciated.
Old May 27, 2004 | 06:20 PM
B18C1CYA's Avatar
Default Re: Install help (etrauty)
your going to have to put the ait sensor in the intake pipe to the turbos inlet, and the vacum lines t them into the brake booster line that will give you a good vacum and boost signal
Old May 27, 2004 | 06:26 PM
etrauty's Avatar
Default Re: Install help (B18C1CYA)
Since there is not a hole already there, I Should drill one then??
Old May 27, 2004 | 06:31 PM
B18C1CYA's Avatar
just drill the hole the same size as the one in your short ram intake and just but the gromit in the inlet pipe for the turbo and you might have to lenghten the wires for the sensor, just make shure you solder them
jdmfreak1992
Honda Civic (2001 - 2005)
Mar 6, 2009 04:22 AM
EM2Tuner08
Mar 14, 2008 01:38 PM
jeffk182
Feb 17, 2006 05:31 PM
b16 matt
Mar 28, 2003 02:40 PM
queez
Mar 10, 2003 04:47 PM
