inline fuel pumps
Old Jun 5, 2002 | 01:06 PM
SGR Teg's Avatar
Default inline fuel pumps
where do you guys install your inline pumps at? i heard they won't let you race at the track with the pump on the firewall. just getting ideas where you guys put them. thanks!
Old Jun 5, 2002 | 02:06 PM
sushibug's Avatar
Default Re: inline fuel pumps (SGR Teg)
i never heard of that but mine is installed on my strut bar. i used electrical tape around the strut bar to help eliminate some vibration.
Old Jun 5, 2002 | 06:53 PM
SGR Teg's Avatar
anybody else? any ideas? thanks
Old Jun 5, 2002 | 09:49 PM
DA666's Avatar
www.theoldone.com/articles/fuelpump/
Old Jun 5, 2002 | 09:57 PM
ThePunk's Avatar
Default Re: inline fuel pumps (T3T4DA6)
I thought the idea was to keep the in-line as close to the fuel rail as possible, to keep the pressure high?
Old Jun 5, 2002 | 10:34 PM
quickspoolin's Avatar
I've seen alot of setups mounted on the upper pipe going into the throttle body.
Old Jun 6, 2002 | 04:26 AM
T3EMSI's Avatar
Thanx for the link, good info.
Old Jun 6, 2002 | 04:36 AM
LEON's Avatar
Default Re: inline fuel pumps (rickys2000si)
I have mine under the car near the fuel tank
Old Jun 6, 2002 | 04:38 AM
DSF's Avatar
DSF
Default Re: inline fuel pumps (LEON)
I always heard this was the preferred method. Something about inline pumps being better "pushers" than "pullers".
Old Jun 6, 2002 | 08:14 AM
Coldsi's Avatar
Default Re: inline fuel pumps (DSF)
I guess you're talking about a booster pump which would need to be mounted in the engine bay near the fuel rail. Some people are confusing an in-tank pump with a booster pump.
Old Jun 6, 2002 | 05:35 PM
Ben Huynh's Avatar
If you have a B series engine, the best spot is right above the transmission/starter. Look for a single bolt near the starter, make a bracket to hold your pump, and bolt it up. All the noise coming from the pump is absorbed and it is perfectly situated between the filter and rail.
Adinfinitum
Apr 14, 2008 12:07 PM
B18c1turboedEK
Feb 28, 2007 02:01 PM
poorboyj
Dec 16, 2005 10:36 AM
edger8cer
Mar 1, 2005 08:05 AM
revhrdls
Sep 2, 2001 11:42 AM
