inline fuel pump problem
Old Jun 30, 2002 | 10:08 PM
SGR Teg's Avatar
Default inline fuel pump problem
i drive my car with inline b/w filter and rail and with a 12:1 fmu and after about 10-15 minutes of driving my car bogs and backfires then it drives fine for a little and does it again. so i took the inline out and drove around still same thing so i took the fmu off and drove around and went away so i took the fmu back to vortech and i guess they put in a new spring so everything was working. then i put my inline back on again today and it starts bogging and backfiring again. anyone have these problems. i have the msd inline fuel pump on my 90 integra. thanks!
Old Jun 30, 2002 | 10:29 PM
rjardy's Avatar
Default Re: inline fuel pump problem (SGR Teg)
you drove your shiz without an fmu? carefull now, i hope you werent boosting! but not to belittle you but have you checked the polarity of your inline fuel pump? common problem...
Rob
Old Jun 30, 2002 | 10:38 PM
SGR Teg's Avatar
Default Re: inline fuel pump problem (rjardy)
i just set my fuel pump with that relay like they showed on one of the posts in this forum. how do i check the polarity? not really into the electronics and wiring stuff. thanks
Old Jun 30, 2002 | 10:41 PM
rjardy's Avatar
Just double check that you dint wire the + to the- and vice versa.....its messy but take off the out put line and run the pump and make sure its not running the motor backwards, it should push fuel out not suck in....
HTH
Rob
Old Jun 30, 2002 | 10:49 PM
SGR Teg's Avatar
i'm pretty sure everything is wired correctly. i've checked that many times when i took it off and put it back on. is there anything else that could be wrong? thanks
Old Jun 30, 2002 | 11:26 PM
rjardy's Avatar
Are you using the intank allso?
Rob
Old Jun 30, 2002 | 11:32 PM
SGR Teg's Avatar
just the stock one.
Old Jul 1, 2002 | 01:27 AM
rjardy's Avatar
you just confused me, so you are using the intank (stock) and an an in line right?
Rob
Old Jul 1, 2002 | 08:23 PM
SGR Teg's Avatar
yeah
SIK IN DA HED
Nov 18, 2003 10:30 AM
harryg
Sep 24, 2003 01:47 PM
b18tdelsol
May 19, 2002 07:09 PM
sushibug
Apr 6, 2002 04:50 PM
