inline fuel pump is noisy.....how do i fix?
Old Apr 18, 2002 | 07:19 PM
uneekcrx's Avatar
Default inline fuel pump is noisy.....how do i fix?
i have this thing mounted on the firewall and it's extremely noisy...is there another place in the engine bay or something i can do to quiet this fuel pump down some
Old Apr 18, 2002 | 07:38 PM
dustin's Avatar
Default Re: inline fuel pump is noisy.....how do i fix? (uneekcrx)
you wired the correct direction right
Old Apr 18, 2002 | 07:45 PM
shadowdawn's Avatar
Default Re: inline fuel pump is noisy.....how do i fix? (dustin)
Mabye some dynamatt or other sound-deadener between it and the firewall. My MSD inline isen't all that loud, a nice quiet hum when the car has NO radio on at idle... (don't listen to any music since I got turbo... that whine is SO goddamn sexy)
Old Apr 18, 2002 | 08:10 PM
uneekcrx's Avatar
Default Re: inline fuel pump is noisy.....how do i fix? (shadowdawn)
yea it all works correctly but i jus t need to quiet it down some..........and install the fuel pressure guage after the new fuel pump
Old Apr 18, 2002 | 08:21 PM
BoostinDC2's Avatar
well i mounted( zip tied ) my inline to the a/c lines and it was quiet
Old Apr 18, 2002 | 09:00 PM
Teg4e's Avatar
Yes, I've heard mounting the pump onto something solid or near the engine compartment will be noisy. Try mounting it how Dustin did here:
http://imglib.************/index.cgi?cmd=viewimage&id=2 http://imglib.************/index.cgi?cmd=viewimage&id=3
Old Apr 18, 2002 | 09:06 PM
MugenSi00's Avatar
Default Re: inline fuel pump is noisy.....how do i fix? (Teg4e)
SX 1000cc pump is looooooooooouuuuuuuuudddddddddd!
Old Apr 18, 2002 | 09:07 PM
BoostinDC2's Avatar
http://imglib.************/index.cgi?cmd=viewimage&id=2</a> <A HREF="http://imglib.************/index.cgi?cmd=viewimage&id=3" TARGET="_blank">http://imglib.************/index.cgi?cmd=viewimage&id=3
thats how i did it u can barely hear it
Old Apr 18, 2002 | 09:43 PM
CM-R's Avatar
Default Re: inline fuel pump is noisy.....how do i fix? (BoostinDC2)
Thats exactly what i did also...
Old Apr 18, 2002 | 09:52 PM
Slater's Avatar
Default You think that would work with an in-tank pump?
I'm sure it would, as long as the gas didn't act as a solvent and eat up the rubber.
My Walbro in-tank whines like a 2 year old. I put a few sheets of dynamat over the fuel tank cover, which helped considerably but now I hear a muffled whine. I'm sure adding that that rubber hose clamp would quiet it completely.
- Slater
Old Apr 18, 2002 | 10:03 PM
turbopimp's Avatar
Use an adel clamp (looks like an ignition coil clamp) and mount the pump on a bolt on the transmission. This way the pump vibration and noise will be isolated from the chassis. It is very quiet if done this way.
Old Apr 18, 2002 | 10:04 PM
SIK IN DA HED's Avatar
New User
Default Re: You think that would work with an in-tank pump? (Slater)
i zip-tied my inline fuel pump to the big thick hoes near the fuel filter. not sure what hose that is... but its not as loud as my friends fuel pump that is mounted on the firewall.
Old Apr 18, 2002 | 10:26 PM
intekragsr's Avatar
Default Re: You think that would work with an in-tank pump? (dlplayboy)
i thought mine was loud, until I realized it was wired with the wrong polarity, then it was pretty quiet
civicgsr209
Oct 13, 2004 10:37 PM
prelude994e
Sep 13, 2004 11:23 AM
sleeperHatch
11
Jul 31, 2004 12:14 PM
zerodrag29
Mar 1, 2002 09:51 PM
Lei Siew Long
Feb 4, 2002 06:49 PM
