Injetors for a obd2 B16a2
Old Jan 5, 2009 | 05:29 PM
Boosted00Si's Avatar
Default Injetors for a obd2 B16a2
ok ive been searching and searching and searching. ok scince i have obd2 can i use DSM injectors and their Resistor box??? Is there any Injectors out there thats Plug and Play and can support 10-12psi on a Sr20 T25 Turbo?? I still plan on Keeping my car OBD2 can any1 please let me know
Old Jan 5, 2009 | 05:49 PM
TheShodan's Avatar
Moderator
Default Re: Injetors for a obd2 B16a2
You can only get about 220whp on that turbo anyway, so even Greddy 310s can work for that plug n play.
Old Jan 5, 2009 | 05:51 PM
jdm602's Avatar
turbo + obd2 = not safe.
Old Jan 5, 2009 | 05:55 PM
Wht you mean?
Old Jan 5, 2009 | 05:56 PM
What other injectors 450cc or higher that are plug and Play??
rmcdaniels's Avatar
I just soldered OBD1 clips onto mine, RC sells them brand new for $10.
Old Jan 5, 2009 | 06:06 PM
So your orderd RC Injectors and just spliced them in?? you didnt need another Resistor box?
Old Jan 5, 2009 | 06:14 PM
jdm602's Avatar
Originally Posted by Boosted00Si
Wht you mean?
you cant tune obd2.
if your gonna turbo your car. get an obd1 ecu so you can tune it. along with a jumper harness.
and for injectors. just get some of the dsm blue top 450's with a resistor box. you can use a dsm resistor box, or the old da integra and ef civic ones. and youll need the obd1 injector clips for the injectors.
Old Jan 5, 2009 | 06:21 PM
rmcdaniels's Avatar
The wiring harness has nothing to do with tuning.
I bought saturated injectors so I didn't need an injector box. That works up to a point, and saturated 450's work fine. I'm currently using peak/hold 1000's, so I'm back to using an injector box. If you use DSM injectors then you will need to wire in an injector box. It just takes a few minutes with a soldering iron to wire it all up.
Old Jan 5, 2009 | 06:22 PM
you cant tune obd2.
Obd1 Injector clips? can i use the dsm clips and just splice them in? so if i get DSM Injectors all i have to do is install a 90 Integra Resistor box? Do i Have to splice in the DA Resistor Box?
Sorry For the Newb Questions but i reall need to know
Old Jan 5, 2009 | 06:27 PM
jdm602's Avatar
yea you can do that too.
as for the resistor box. i found its easiest to take the four yellow/black wires from each injector and solder them to the red one on the box, then distribute each one of the black wires back to each one of the injectors, order irrelevant.
Old Jan 5, 2009 | 06:29 PM
rmcdaniels's Avatar
Any OBD1 clips should be fine as long as they fit on the injectors. Any resistor box should be fine as well. I see them for $20 on ebay all the time. I usually keep a couple extra around just in case.
Old Jan 5, 2009 | 06:30 PM
So do i need to splice the 90 Integra Resistor Box in?
Old Jan 5, 2009 | 06:31 PM
rmcdaniels's Avatar
Yes, do it like jdm602 said.
Old Jan 5, 2009 | 06:40 PM
can some1 please post the link for the write up to wire up the DA box to a obd2 car
Thank you in advance
Old Jan 5, 2009 | 06:44 PM
97_coupe's Avatar
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Old Jan 5, 2009 | 06:46 PM
rmcdaniels's Avatar
Search:
https://honda-tech.com/forums/acura-integra-6/resistor-box-wiring-1364840/
Old Jan 5, 2009 | 07:00 PM
jdm602's Avatar
lol heres the article quoted.
Navy_Kyle
Aug 6, 2012 12:41 PM
EX-T
Jun 21, 2007 05:16 AM
jdmef-9
Mar 15, 2007 10:28 PM
DougieStyle
Jul 14, 2006 08:06 AM
willyboyK20
Mar 13, 2006 07:06 AM
