which injectors to use?
Old Jun 14, 2009 | 08:54 PM
ctr32's Avatar
Default which injectors to use?
Hey guys have boosted ls with 450cc dsm injectors with the resistor box ..I get fuel cut off 1st gear cause there maxed out..now i want to get new ones but should I stay with dsm or get ones for the b18? and if i get the ones with a b18 do i just leave the resistor box alone? take out?
Old Jun 14, 2009 | 09:05 PM
DC4KiD's Avatar
Default Re: which injectors to use?
At least give us your detailed setup, and a power goal...
Old Jun 14, 2009 | 09:18 PM
ctr32's Avatar
* B18b1
* Eagle rods
* JE pistons (9:1)
* Port and polished head
* Feera valves
* Crowler cams
* Crowler retainers
* Crowler springs
* Victor X intake
* AEM fuel rail
* AEM fuel regulator
* Block guard
* T70 turbo
* Big intercooler
* Aluminum radiator
* Tial waste gate
aiming around 400 450
Old Jun 14, 2009 | 10:04 PM
TheShodan's Avatar
Moderator
If you have actually tuned and maxed out your injectors, and have actually hooked up the resistor box correctly, you can use any larger Low impedence injector without Resistor box removal. from 580cc-1000cc. YOU WILL HAVE TO RETUNE THE CAR FROM SCRATCH WITH THE NEW INJECTORS.
Old Jun 14, 2009 | 10:07 PM
ctr32's Avatar
it has been tuned and everything..resistor box is hooked up correctly...so theres no really difference running dsm injectors over b18 ones? I was planning on buying Precision Turbo DSM 1000cc Injectors ....I do planning on getting it tuned when i get the new injectors
Old Jun 14, 2009 | 10:21 PM
TheShodan's Avatar
Moderator
By B18 you mean saturated injectors? or DSM o-rings and fitment? Get the honda ones fitted to your fuel rail, and keep the resistor box.
Done.
Old Jun 14, 2009 | 10:23 PM
ctr32's Avatar
good deal!!
wwolf771177
Jan 8, 2012 08:57 PM
CivSiClone_96
Dec 20, 2009 05:52 PM
accord2nrz
Nov 27, 2008 12:03 AM
ickyhonda
Apr 9, 2008 01:50 PM
b16hatche
Oct 24, 2005 08:03 PM
