Injectors missing pin tabs...
Old Jan 31, 2005 | 02:45 PM
dturbo's Avatar
Default Injectors missing pintle caps...
I bought a set of used dsm injectors off another forum. Two injectors are missing the black tabs that go over the bottom pin thing. Will it cause any problems if I dont have them there?
Modified by flyazzcivic at 4:39 PM 2/1/2005
Old Jan 31, 2005 | 03:41 PM
beepy's Avatar
Default Re: Injectors missing pin tabs... (flyazzcivic)
Yes, you could lose the O-rings in the engine next time you remove them. But, you should get new O-rings and new pintle caps anyway.
Old Jan 31, 2005 | 07:31 PM
dturbo's Avatar
Default Re: Injectors missing pin tabs... (beepy)
where do i get the pin tabs and o-rings from? will the honda o-rings and pin tabs fit?
Old Jan 31, 2005 | 07:43 PM
slowgti's Avatar
probably rc engineering.
Old Feb 1, 2005 | 03:39 PM
dturbo's Avatar
Default Re: (slowgti)
will the injectors work properly if I just run the injectors without the pintle caps?
Old Feb 1, 2005 | 04:03 PM
project dc2's Avatar
Default Re: (flyazzcivic)
yes theyll work fine. just dont drop them.
Old Feb 1, 2005 | 05:20 PM
JRciv's Avatar
Default Re: (project dc2)
Do a search you doofus. I would flame you, but you probably just didn't know that the "pin tabs " are called "pintle caps".
An archived search for "pintle caps" yields only four threads, all of which can answer your question. Ah, what the hell. I'll just do the search for you. You newbs will be the death of me.
https://honda-tech.com/zerothread?id=1059258
https://honda-tech.com/zerothread?id=449913
https://honda-tech.com/zerothread?id=647976
https://honda-tech.com/zerothread?id=254115
b16a4
Aug 1, 2007 06:50 AM
!0SeCoNdSleEpEr
Feb 8, 2004 02:23 PM
Big Josh
Dec 13, 2003 10:47 PM
DAinfamousR
Nov 14, 2003 06:31 PM
20psiSR20
Jun 28, 2002 07:42 PM
