injectors for 1 bar.
Old Nov 5, 2001 | 07:36 PM
InfamousRS's Avatar
Default injectors for 1 bar.
Will RC 550's support 1 bar? if not what will? what would be needed for more that a bar, like 1.5 bar on the proper bottom end?
Old Nov 5, 2001 | 08:26 PM
dustin's Avatar
Default Re: injectors for 1 bar. (BLK94RS)
They will, I would suggest running baseline fuel pressure around 55-60psi for safety.
Dustin
Old Nov 5, 2001 | 08:59 PM
InfamousRS's Avatar
Default Re: injectors for 1 bar. (dustin)
Thanks.
Old Nov 5, 2001 | 09:04 PM
LsTurbo91's Avatar
make sure you have the pump to support it aswell.
Old Nov 5, 2001 | 09:13 PM
DIRep972's Avatar
Smarter than you
Default Re: injectors for 1 bar. (LsTurbo91)
this is kinda unrelated but when people switch from FPR to hondata do they keep their high pressure fuel pump?
[Modified by DIRep972, 6:13 AM 11/6/2001]
InfamousRS's Avatar
WILL WALBRO DO?
Old Nov 5, 2001 | 09:23 PM
LsTurbo91's Avatar
Default Re: injectors for 1 bar. (DIRep972)
no need to if your gonna boost under 10psi, I currently have my inline pump out to mount it by the fuel tank and take my stock pump out. I have no problems with the stock pump as long as I keep my fuel pressure down. The volume decreases as fuel pressures go up with a stock pump. I intend to raise my pressure up to compensate higher boost with 440's for the meantime until i get some 720's.
turbolsvtecej1
Sep 7, 2014 04:06 PM
B18c1turboedEK
Feb 28, 2007 02:01 PM
poorboyj
Dec 16, 2005 10:36 AM
edger8cer
Mar 1, 2005 08:05 AM
Anubyss
Apr 23, 2003 06:54 AM
