injector sizes
Old Feb 2, 2004 | 09:44 AM
chinners10's Avatar
Default injector sizes
how do you determine what size injectors to run??? i have a B18B1 in my hatch with a DRAG III turbo kit..i've got a AEM fuel rail, and AFPR, MSD ignition, port & polished head, crower valvetrain, 8.8:1 compression wieseco pistons, and eagle H beam rods, how do i know what size injectors i should go with?? i was thinking 500cc's does that sound about right?
Old Feb 2, 2004 | 09:46 AM
b18bturbo's Avatar
Default Re: injector sizes (cxhatch02)
great place to start learning about sizing injectors is efi101.com and rceng.com they have tons of information that will help you determine the right size you need.
aka010010
Guest
Posts: n/a
rc injectors 550cc. u should have no problems runnig them. could you tell us what ur using as a fuel management too?
Old Feb 2, 2004 | 09:47 AM
b16ahybrid's Avatar
Your form of fuel management determins what size of injector you can run.
Beyond that you use your desired hp goal to calculate your injector size.
what are your hp goals and how are you going to tune your fuel curve?
Old Feb 2, 2004 | 10:50 AM
chinners10's Avatar
Default Re: injector sizes (b16ahybrid)
im gonna run Hondata s200 w/boost.. my goal is 280-300 hp ive got a FMU, fuel rail, and adj. fuel pressure regulator right now.. any more ideas?? thanks for the links too..
Old Feb 2, 2004 | 10:51 AM
yellowturbo's Avatar
you will be fine with 550cc !
Old Feb 2, 2004 | 10:54 AM
chinners10's Avatar
Default Re: (yellowturbo)
i don't have a injector resistor box... do they make 550cc's that don't need to run a resistor box??
Old Feb 2, 2004 | 11:06 AM
JDogg's Avatar
Default Re: (cxhatch02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxhatch02 &raquo;</TD></TR><TR><TD CLASS="quote">i don't have a injector resistor box... do they make 550cc's that don't need to run a resistor box??</TD></TR></TABLE>
yes they do. rc makes some and so does precision
Y2K Si FBP
May 23, 2011 05:08 AM
rollhondahard
Nov 3, 2008 06:02 AM
PnkRokCountryboy
Jun 14, 2005 07:42 AM
Sinner
Dec 23, 2003 07:09 PM
JustAnotherHonda
Mar 9, 2003 09:15 PM
