injector seals
Old Jan 22, 2005 | 06:30 PM
huntarrr's Avatar
Default injector seals
Putting DSM 450's into my d16y7/8 mini me.
Which lower injector seals (the ones that sit in the manifold) do I need to get? I know I can dremel the stock ones, but I'd rather just be able to buy some that'll fit right in.
Where can I get them? Will the stock DSM seals fit in a y8 manifold? TIA
Old Jan 22, 2005 | 06:42 PM
93turbo16's Avatar
they won't fit right. You have to dremel them out to my knowledge. its an easy job.
Old Jan 22, 2005 | 07:06 PM
huntarrr's Avatar
Default Re: (93turbo16)
Do you happen to know the dremel bit part number I use?
I've 'attempted' it once already, but had trouble holding the seal in a perfect circle so that the dremelling wouldn't be all lopsided.
I don't have an extra manifold lying around that I could use, and I don't want to dremel while the seals are in the mani to avoid getting shavings into the motor.
Any hints/suggestions to make it easier?
Old Jan 22, 2005 | 07:10 PM
93turbo16's Avatar
a dremel part number, are you serious? Just use a dremel, any that works... I just put it on the ground and held it I think with my hands, wearing gloves. It doesn't have to be a "perfect" circle. It will expand a little bit when you put it over the end of the injectors. Just so it gets a snug fit is fine.
mikegeezy
Mar 5, 2007 09:10 PM
importdude2000
Apr 20, 2006 12:50 PM
debogsr
Sep 3, 2005 07:19 PM
Pikachu
Aug 13, 2005 01:55 PM
Mikey3000
Mar 19, 2002 11:21 AM
