injector question
Old Jan 22, 2007 | 09:46 AM
gsr1289's Avatar
Default injector question
will stock injectors work fine on a turbo setup if im only running like 7 lbs of boost?
thanks
Old Jan 22, 2007 | 11:44 AM
doood's Avatar
been there done that
Default Re: injector question (gsr1289)
what engine? what turbo? what ems?
use bigger injectors so you have room to grow
Old Jan 22, 2007 | 06:25 PM
gsr1289's Avatar
Default Re: injector question (doood)
oh sry i forgot to include that info its a b18c1 itll be a t3/t4 turbo and ill prolly use chrome
Old Jan 22, 2007 | 06:28 PM
Zeusfire69's Avatar
Get yourself some 450cc injectors from a DSM, they are cheap and they work well. They do need resistors or resistor box though. To answer your question, No, stock injectors are too small..
Old Jan 22, 2007 | 07:27 PM
gsr1289's Avatar
Default Re: injector question (Zeusfire69)
okay thanks. how hard is it to install the register box?
Old Jan 30, 2007 | 11:43 AM
Zeusfire69's Avatar
Here's two links on how to do it two different ways...
http://robskills.wordpress.com...-loom/
http://www.homemadeturbo.com/t....html
Old Jan 30, 2007 | 11:45 AM
ryan89crx's Avatar
another link with Radio Shack resistors
http://www.d-series.org/forums...=7216
Old Jan 30, 2007 | 12:51 PM
dpetro1's Avatar
you definitely need bigger injectors, unless you are using an fmu which i hope you arent. if you dont wanna worry about the resistor box you can get saturated injectors, a bit more expensive than used dsms but easier to install. also the 450s are only good till about 300whp.
motoxracer98
Mar 18, 2013 03:28 PM
sloganish
Nov 24, 2006 11:23 PM
jdmcivicb16
Jan 17, 2004 02:58 PM
Dancing is Forbidden
Dec 8, 2002 09:05 AM
