Injector Problems
Old Aug 13, 2010 | 04:37 PM
hatchaneg's Avatar
Default Injector Problems
Problem:
My last d16z6 blew because cylinder 2 leaned out so when I swapped a new d16 in (using same fuel rail and injectors from the blown motor) i listened to the injectors. Just as i suspected, injector 2 sounded different (clicking is not as pronounced as other injectors) so I thought it would be an easy fix and ordered a new injector.
I got the new injector, put it in today BUT it still sounds different like the old "bad" injector. Sure enough, i took it for a drive and when the motor really needs all the fuel it can get (full boost and high revs in vtec) i feel the same hesitation again.
Why would this injector not be firing as well as the others?
Anyone had this problem?
I know if I don't figure this out it's gonna lead to another blown motor.
Old Aug 13, 2010 | 04:42 PM
SL0WEGG's Avatar
Default Re: Injector Problems
what injectors? check your wiring.
Old Aug 13, 2010 | 05:16 PM
hatchaneg's Avatar
racetronix 42 lb/hr, wiring looks alright...it still works, the pulse just isnt as strong.
Old Aug 13, 2010 | 06:51 PM
BlownSihatch's Avatar
Is the car tuned?
Definitely check the wiring.
Old Aug 13, 2010 | 07:09 PM
hatchaneg's Avatar
yeah tuned on crome, im gonna go through the wiring tomorrow.
Old Aug 13, 2010 | 08:01 PM
Has the car ever run well on the tune?
Old Aug 13, 2010 | 09:52 PM
hatchaneg's Avatar
Yeah ran perfect for over a year then started hesitating, which lead to the motor blowing, now trying to figure out the issue before it blows again
Old Aug 14, 2010 | 03:24 AM
7rrivera7's Avatar
Try swapping the ECU - the injectors are powered by dual transistor banks, 1 per set of 2 injectors, which can go bad. Next time swap your injectors before buying a replacement to see if the problem "moves" with the injector ;-)
Old Aug 14, 2010 | 07:22 AM
hatchaneg's Avatar
is there a way to check the transistor banks?
i just did a power check, each plug is sending 13.1x volts to the injector and each injector has 17 ohms of resistance on a 2000 scale... the injector on cylinder 2 still sounds different from the other 3. i'm stumped.
Old Aug 14, 2010 | 09:31 AM
7rrivera7's Avatar
You will see 12v on the injector plugs but the ECU actually grounds them to pulse them - not the other way around so your best bet is to still run another ECU in your car or your ECU in another car.
Old Aug 15, 2010 | 07:08 PM
hatchaneg's Avatar
changed the ecu, still having the same issue. also checked the voltage at the ecu, its fine as well.
Old Aug 21, 2010 | 10:42 AM
hatchaneg's Avatar
it was the distributor!! thanks for your help guys
ehwreckuno
K Series
Mar 20, 2016 05:18 PM
98vtec
12
Feb 12, 2008 03:30 PM
ham
Sep 3, 2007 11:09 AM
trbob16a
Apr 17, 2003 12:41 PM
