injector problem, HELP!!!!
Old Nov 15, 2002 | 04:02 PM
Mr.DC2TurBo's Avatar
Default injector problem, HELP!!!!
I'm in the middle of install right now. I have RC 440 cc injectors going into a 01 LS integra. I took the stock ones out and put the RC injectors in. It was a tight fit and the stock clips don't fit the RC?? How do I fix this or is this for the wrong injectors for my car?
Old Nov 15, 2002 | 04:11 PM
Flamenco-T's Avatar
Default Re: injector problem, HELP!!!! (Dr.TurBo2006)
you need an OBD clips and re-wire the clips..or you can get an RC clips as well
Old Nov 15, 2002 | 04:17 PM
Default Re: injector problem, HELP!!!! (Flamenco-T)
So the injectors are right for my car? I just need obd clips or rc harness? How come and where can I get either? Are u saying the rc injectors are made for obd1 and not my obd2? For the Rc harness, does that just connect to my injectors and the other end connect to the stock hareness or will I have to splice too?
Old Nov 15, 2002 | 04:25 PM
Sonny's Avatar
You will have to cut the stock injector clips off of your injector harness and solder in RC clips or OBD0/OBD1 clips. Pisser, man...that sucks that you got that far before you realized it.
Sonny
Old Nov 15, 2002 | 04:50 PM
Default Re: injector problem, HELP!!!! (Sonny)
F*cK I know... I sold my fmu and bought 440cc with the s-afc. Okay, new question... Can I run STOCK LS injectos with the s-afc and a aem fpr until I get the RC CLIPS??? I have no FMU and I have an intank pump with this setup... Thanks for the helps. Also I want to run 8psi with this? Is this do able and yes I have boost controller.
fortynineR
Aug 30, 2007 03:08 PM
TheSwift1
Jul 31, 2004 07:04 PM
Type RS
Jul 6, 2003 01:52 PM
SlamMan
Jun 13, 2003 04:41 PM
