Injector Issue
Old May 23, 2011 | 08:01 AM
civic-r11's Avatar
Default Injector Issue
I have been looking around for buying bigger injectors for my turbo setup which consists of; 85mm bore gsr sleeved with foreged pistons and eagle rods, on a 6265 precison billet turbo.. i have 1000cc low impedence injectos and was want 2000cc.. I know that i should just save up and get the ID'S 2000's but i found these injectors.. and was wondering if anybody has used these on there cars yet? Im thinking of buying them.. thanks in advance..
http://www.fiveomotorsport.com/honda...fuel-injectors
I have seen people talk about using these.. but has anybody had any good things to say about using these?
Old May 23, 2011 | 10:15 AM
tony1's Avatar
Default Re: Injector Issue
Here's a bit of info on them.
http://injectordynamics.blogspot.com...ctor-in-3.html
Old May 23, 2011 | 10:32 AM
Garage 808 Hatch's Avatar
lulz
Old May 23, 2011 | 10:46 AM
civic-r11's Avatar
Originally Posted by tony1
So I'm guess these injectors are not good/ won't work?
Old May 23, 2011 | 12:18 PM
Depends on your definition of work. Im sure someone could make a car run with the fuel line just going in to the TB with no injectors
Old May 23, 2011 | 03:59 PM
Dynamic Performance Racing's Avatar
I would look into Fuel Injector Clinic. We use them on our race cars and our customer cars and they work great. It works well with E85 or other high volume fuels. They also don't need a resistor back or injector drivers. Also when you get them it includes the pigtails. Check out their website for a wide range of selection. http://www.fuelinjectorclinic.com/honda/
PM us if you have any questions.
Old May 23, 2011 | 05:05 PM
civic-r11's Avatar
I was going to run these injectors.. which are all the same with the id's the only difference is the colors.. bosch makes all of them.. but the injectors that i posted orginally i really want to know if they work
Old May 23, 2011 | 05:21 PM
tony1's Avatar
Here's a bit about one of the things that makes Injector Dynamics different from the rest on the ID2000's.
http://www.injectordynamics.com/dynamicmatch.html
Not to mention correct injector data for every application.
Old May 23, 2011 | 05:48 PM
civic-r11's Avatar
tony i understand what you are saying about those injectors.. i am just trying to see if they would work.. and i am seeing that they are not so good after all.. but i don't have a grand to spend on injectors.. my setup is a 85mm sleeved gsr on a 6265 turbo.. i have low impedance 1000cc on a dw301 in tank pump and a bosch 044 inline.. i know i need these 2000cc injectors.. but cant afford for about 2 months..i know i am not going to make 600ish on e85.. with this setup..
Old May 23, 2011 | 05:56 PM
tony1's Avatar
It's not a big difference, but you can save a little and do the ID1600's and still have plenty of fuel for your goals.
Think about how critical the fuel injectors are to proper running and reliability, it's not a place you want to cut corners. It really can be the difference between a car that runs great and a car that doesn't, or a car that runs reliably vs a car that loses an engine.
Old May 24, 2011 | 12:52 PM
Well stated Tony!
Do more research and ask around what works. Also make sure the ones that you ask around actually uses the product... lol. Just like myself and Tony.
We have a customer with a similar set up like yours and the FIC that we recommended them works great!
Old May 25, 2011 | 04:45 AM
4cylfiend's Avatar
Save up and get the ID2000's. I love my ID1000s but now I already need to upgrade to the 2000s and they are only a month old. Should have just forked out the money from the get go.
Old May 26, 2011 | 08:27 AM
civic-r11's Avatar
True.. I am going to.. i was just thinking about buying those cheap injectors.. and see if they work well.. but i don't want to blow up my motor eithier.. so i am just going to save up and buy the FIC'S or ID'S when i get the money
Old May 26, 2011 | 08:40 AM
4cylfiend's Avatar
Ya, Tony is right about not cutting corners on your fuel system. Hes definatly an expert on this stuff. You will be 100% satisfied with the Injector Dynamics tho.
walrus_07
Jun 20, 2012 07:21 AM
ticaaal70
Aug 2, 2010 06:41 PM
theonecalledtodd
Oct 25, 2009 11:00 AM
VTC_CiViC
Jun 16, 2005 03:53 PM
gamakichi77
Oct 5, 2004 04:07 PM
