injector clips, HELP!!!!
Old Dec 8, 2003 | 08:38 AM
BLACKLUDE97's Avatar
Default injector clips, HELP!!!!
i have a 00 civic si and am gonna put some injectors in, what year injector clips do i have to get? what is the wiring diagram? what wires get tapped into what wires??? someone help!!!! please
Old Dec 8, 2003 | 08:43 AM
b18bturbo's Avatar
Default Re: injector clips, HELP!!!! (BLACKLUDE97)
you need obd 1 clips and wire them in line to your existing harness. that is about all you need to do. if you have saturated injectors no need of a resitor box if you have peak hold you will also need to wire in a resistor box inline to the inejctors
Old Dec 8, 2003 | 08:46 AM
can i also run individual resistors? http://liam821.com/pix/?path=c...r.JPG also can i go to like autozone and ask them for 92-95 injector clips and those will work??
Old Dec 8, 2003 | 09:10 AM
mike1114's Avatar
Default Re: (BLACKLUDE97)
IF your using DSM injectors you can modify your them to work with your injector clips.
Look inside the dsm injector top where the clip goes. There is a little plastic guide thats vertical that, of course, helps guide the clip on.
Take a blow torch and a coat hanger (wear gloves) and heat up the coat hanger and then melt the plastic guide off. Make sure you get all of it, keep trying till the injector clip slips right on.
I did this to my dsm injectors in my gsr motor and it works perfect!!!!!! Looks nicer than wiring in new clips too. Then all ya gotta do is use resistor box or get individual resistors, I went the the box cause I got one for free!!
Old Dec 8, 2003 | 10:14 AM
Cruiser G's Avatar
Default Re: (mike1114)
Hes right, but first you need obd1 clips. The clips that come with your car will not work.
Old Dec 8, 2003 | 11:05 AM
mike1114's Avatar
Default Re: (Cruiser G)
true, forgot about the obdII
Old Dec 8, 2003 | 10:16 PM
so the wires from the obd1 clips are the same color as the obd2 clips?
Old Dec 8, 2003 | 11:19 PM
99blackcivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACKLUDE97 &raquo;</TD></TR><TR><TD CLASS="quote">so the wires from the obd1 clips are the same color as the obd2 clips?</TD></TR></TABLE>
No
stripe to stripe
no stripe to no stripe
Old Dec 9, 2003 | 07:01 PM
filtereds0ul's Avatar
so if the car is already equipped with odbI clips (94 integra) the dsm injectors will fit no problem? thanks
Old Dec 9, 2003 | 10:58 PM
Cruiser G's Avatar
Default Re: (filtereds0ul)
Right, but you'll have to bore out your seals and trim a little tab off of the the dsm injectors to fit the obd1 plugs.
Old Dec 10, 2003 | 02:21 AM
project dc2's Avatar
or you can get new clips from summit racing, i think 16 bucks plus 8 shipping
comes with 8 clips !!!
msd-2400 is the part number
Old Dec 10, 2003 | 07:14 AM
im not gonna use dsm injectors though. thanks
Old Dec 10, 2003 | 08:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACKLUDE97 &raquo;</TD></TR><TR><TD CLASS="quote">im not gonna use dsm injectors though. thanks</TD></TR></TABLE>
its teh same clips buddy they're OBD=O and OBD I clips . not vehicle specific.
Old Dec 10, 2003 | 01:20 PM
JDMCRX's Avatar
HEY MAN WHERE IS MY $130 I GAVE YOU OVER 2 MONTHS AGO FOR THE AVC-R ILL POST ALL THE EMAILS ON HERE I WANT MY MONEY BACK
SCAMMER
Old Dec 10, 2003 | 01:22 PM
JDMCRX's Avatar
https://honda-tech.com/zerothread?id=588773
ORIG POST HE MADE THIS GUY IS A SCAMMER
Old Dec 10, 2003 | 01:28 PM
JDMCRX's Avatar
Default Re: injector clips, HELP!!!! (JDMCRX)
This message is not flagged. [ Flag Message - Mark as Unread ]
Date: Sun, 21 Sep 2003 12:07:49 EDT
Subject: Re: AVC_R
To: joshbeauchamp@yahoo.com
i get paid oct. 5th. i had spent the money u gave me. i didnt know u
were
gonna change ur mind about it so i spent the money on something i
needed
JDMCRX's Avatar
Date: Sun, 21 Sep 2003 02:20:43 EDT
Subject: Re: AVC_R
yeah, i just have to get paid
Old Dec 11, 2003 | 04:30 AM
ELSpool's Avatar
This kid is a scammer. I'm friends with JDMCRX and he never recieved his money back nor did he get the part.
Old Dec 24, 2003 | 04:25 AM
JDMCRX's Avatar
Default Re: (ELSpool)
Do not help this guy out he is a ****** scammer scammed 4 guys from H-T i want my ****** money bag you ******* ******* i got ur address and when i get more info ill send you a nice xmas gift you ****.
petergriffen
Jul 17, 2006 08:48 AM
thedirty-Dseries
Apr 1, 2006 02:34 PM
80884
Sep 3, 2005 03:13 PM
Panoply
Jul 19, 2005 01:37 PM
Muckman
Mar 18, 2004 07:11 PM
