Info on this turbo please ..........
Old Mar 8, 2004 | 06:23 PM
Squirtin EGsr
Guest
Posts: n/a
Default Info on this turbo please ..........
I picked up a AiResearh T04 on the cold side of the turbo it says A\R.60 and the hot side says A\R 1.14 D. Im thinking about doing a LS motor with Pistons,Rods,Block Guard, Turbo cams, valve spring, Head gasket, AEM EMS, Fuel pump, 650cc injectors, bla bla bla ...... Stock intake manifold prob about 9:1 or 9:5 compression what do you think this turbo would spool around ?
Do you have any other ideas for me its going in a 99 SI. Ill post some pics when i get my dig cam back from a friend.
Old Mar 8, 2004 | 07:40 PM
shadow103rd's Avatar
Default Re: Info on this turbo please .......... (RiceRocket12s)
If the A/R on the hot side is correct that this is the wrong turbo for your setup.....you would never spool it IMO........go with like a .63 on the hot side....someone correct me if im wrong
Jon
Old Mar 8, 2004 | 07:53 PM
XxRoCkMaNxNEOxX's Avatar
Default Re: Info on this turbo please .......... (shadow103rd)
yeah ive seen those w/ the hot side really big i think its like .83 or so. yeah it wont spool as quick. just get a reg. t3/t4
Old Mar 9, 2004 | 02:04 AM
Squirtin EGsr
Guest
Posts: n/a
iv got the turbo and the manifold and the manifold has a T4 flange on it ... so it wont spool at all ?
Old Mar 9, 2004 | 11:37 AM
Joseph Davis's Avatar
Default Re: (RiceRocket12s)
1.14 AR is a bit big for the 5.0 boys when they run singles, that turbo would be better suited to a 350/351.
Swap on a .63 AR turbine housing and enjoy.
Old Mar 9, 2004 | 04:37 PM
Squirtin EGsr
Guest
Posts: n/a
Default Re: (J. Davis)
what if i do a T3 exhaust side ?
Old Mar 9, 2004 | 06:43 PM
Squirtin EGsr
Guest
Posts: n/a
the turbo i have doesnt have a nipple on the cold side.... how would i hook the boost controller up... from the waste gate to controller then where ?
Old Mar 9, 2004 | 06:48 PM
DaX's Avatar
DaX
Loved
Community Favorite
What J.Davis said...a .48 turbine housing from a T3 will suit you. You can either tap the compressor for a nipple or run a vacuum line from your intake manifold [or vacuum distribution block] to your wastegate controller.
Old Mar 9, 2004 | 07:28 PM
Squirtin EGsr
Guest
Posts: n/a
anyone here willing to sell a T3 .43 turbine housing ?
Old Mar 9, 2004 | 07:41 PM
Squirtin EGsr
Guest
Posts: n/a
so is this what i need.... http://store.yahoo.com/cheaptu....html just wanted to see if im buying the right thing!!!
Old Mar 10, 2004 | 02:06 AM
Squirtin EGsr
Guest
Posts: n/a
wake up honda-tech its 6am....
TTT
Old Mar 11, 2004 | 04:22 PM
Squirtin EGsr
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceRocket12s &raquo;</TD></TR><TR><TD CLASS="quote">so is this what i need.... http://store.yahoo.com/cheaptu....html just wanted to see if im buying the right thing!!!</TD></TR></TABLE>
TTT
EJ8Squad919
Jun 6, 2012 07:31 PM
HiProfile
Nov 9, 2007 10:07 AM
RACEPAK
Apr 30, 2006 01:15 PM
Dropped90Integra
Feb 17, 2005 02:29 PM
oMek
Feb 17, 2004 07:48 PM
