Increasing boost pressure problem...
Old Oct 23, 2002 | 04:25 PM
boosted hybrid's Avatar
Default Increasing boost pressure problem...
First let me state my set-up quickly. Max rev log manifold, tial 35mm wastegate and greddy profec b boost controller.
Here is my dilema: I am running on a .45bar spring pressure for my tial wastegate. At one point I could turn up the boost to whatever pressure i desired with the greddy profec b boost controller. My previous engine spun a rod bearing, so i had to do an engine swap and pull my last engine. I replaced everything, everything was working perfectly, then i couldnt boost over .45 spring pressure. I thought i found the problem (the wastegate gasket was leaking), I pulled the wastegate off of the manifold today, cleaned the gasket off, cleaned the flanges, applied wheel bearing grease and installed everything back again. I took the car out for a spin, and cranked up the profec b boost controller and can only get .5bar pressure. I played around with the profec, turning it full tilt and still only .5bar. It seems that there might be an exhaust leak again out of the wastegate, but i cannot imagine that this would limit my boost that much. I would like to hear others opinions on this matter. I do know that when i did run the Tial wastegate gasket on the wastegate, I did not have this problem. I am in the process of ordering the turbonetics fire ring gaskets, but I would like to know what is causing this.
Old Oct 23, 2002 | 05:42 PM
dustin's Avatar
Default Re: Increasing boost pressure problem... (boosted hybrid)
How do you have the profec hooked up to the wastegate?
Old Oct 23, 2002 | 08:54 PM
Default Re: Increasing boost pressure problem... (dustin)
The bottom port is tapped into the brake booster vaccum line, the top port is connected to the "out" port on the profec b boost controller blackbox. The "in" on the black box is tapped into a seperate vaccum source. I used a make shift wastegate gasket that i made up tonight, took the car out for a spin. Hit .65 bar, then turned up the **** again, back down to .5bar. The gasket blew out again, so i guess i need a gasket. I am going to try and make up a copper one, I have some nice 1/8" copper material laying around. This has to be the culprit of my lack of boost.
Old Oct 23, 2002 | 09:25 PM
tony1's Avatar
Use the turbonetics gasket with the "fire ring" and you shouldn't have this problem any more.
Old Oct 23, 2002 | 09:32 PM
dustin's Avatar
Have you tried using no gasket and just some copper spray?
Old Oct 24, 2002 | 06:45 AM
I tried using no gasket and some wheel bearing grease. The grease carbonizes when it gets hot and provides a "gasket" layer. This did not work at all. I am going to try making a copper gasket, if that doesnt work then i will order the turbonetics one.
One more question, my "low boost" channel on the profec b has never worked. I cannot turn up the boost on that channel at all. I think the most that i have gotten out of the "high" boost channel was 18lbs. I dont think the profec is working right...
DarryCar
Apr 18, 2012 03:27 PM
turbodelsolb16a2
Jan 28, 2009 06:54 PM
chilli_822
Jul 25, 2008 03:02 PM
avsrule414
Dec 10, 2005 09:07 AM
_Endless_
Jan 8, 2003 11:24 PM
