IM leak causing idle surge ??
Old Jul 5, 2006 | 04:11 AM
Offer's Avatar
Default IM leak causing idle surge ??
Hey, i just installed the delbrock turbo kit and i'm getting an idle surge from 1000 to 3000 and back to 1000 non stop surging, now is it possible that a intake manifol vacuum leak can cause this surging because i overchecked all my wire connections, my tps sensor, the iacv, the map sensor and everything seem to be fine, i remember sensing some air commin from the intake manifold but i didnt really pay attention to it....could a leak be causing this ??
Old Jul 5, 2006 | 04:49 AM
igo4bmx's Avatar
yes it can.
Old Jul 5, 2006 | 06:56 AM
ramennoodles's Avatar
Default Re: (igo4bmx)
also air in the coolant if you didn't bleed it out can cause a surge. and also make sure you didn't get any of the sensor plugs mixed
Old Jul 5, 2006 | 07:18 AM
RTW DC2R's Avatar
I had similar symptoms when my hose for the PCV had a hole in it.
Old Jul 5, 2006 | 08:22 AM
Offer's Avatar
well, if i disconnected some hoses to change a couple of things around i guess there was air that got in the hoses, is it possible ??
Old Jul 5, 2006 | 08:30 AM
Default Re: (Offer)
if you took any water lines off the engine you would need to bleed it out
Old Jul 5, 2006 | 08:32 AM
Offer's Avatar
how exactly do you bleed it if you dont have a bleed screw ??
Is it possible that you have to pinch the top radiator hose to get the bubbles out ??
Old Jul 5, 2006 | 08:39 AM
Default Re: (Offer)
I'm not sure. maybe you can start engine with cap off an fill as needed. bump, maybe someone else knows
HondaStufff
Jan 28, 2019 10:04 AM
b18egtheehatch
Feb 26, 2015 09:59 PM
brownsEF
Aug 12, 2009 04:34 PM
ericstambaugh07
Jan 20, 2007 01:52 AM
Offer
Jul 5, 2006 09:43 AM
