Ignition module breaks within 100 miles
Old Sep 18, 2012 | 12:13 AM
aRandy's Avatar
Default Ignition module breaks within 100 miles
Does anyone know what could cause an ignition module to fail on an obd1 B18 turbo setup?
The car is still running on std injectors and a preset map to drive a few 100 miles to get it broken in. Only thing is within 150 miles it already ate 2 iginiton modules and starts running on 3 cylinders.
Any ideas what could cause this?
Old Sep 18, 2012 | 01:50 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Ignition module breaks within 100 miles
Check all your grounds, make sure there is no objects in the dizzy floating around, Also look to make sure there is no oil or water in the spark plugs. Also you can check the wires from the dizzy to ecu to make sure none is grounding out.
Old Sep 18, 2012 | 03:34 PM
Casey's Avatar
what management?
Old Sep 19, 2012 | 01:07 PM
aRandy's Avatar
Neptune
Old Sep 19, 2012 | 01:19 PM
Muckman's Avatar
Moderator in Chief
Heat. Put a temp probe there and monitor the temp at the distributor.
RuneRavenX
12
Mar 20, 2013 07:35 PM
ls19integra95
Sep 6, 2007 06:29 PM
sahtt
Feb 4, 2005 12:04 PM
fast94ex
Nov 30, 2004 07:56 PM
mt23vtecbb2
Jul 16, 2003 07:43 PM
