Ignition Coil heat temp limit
Old Oct 29, 2007 | 11:47 AM
Muckman's Avatar
Moderator in Chief
Default Ignition Coil heat temp limit
Does anybody know the maximum heat range of the factory ignition coil? Obviously 270*F is too hot
Old Oct 30, 2007 | 08:05 AM
Muckman's Avatar
Moderator in Chief
Default Re: Ignition Coil heat temp limit (Muckman)
Any idea at what temp the honda coil will fail?
Old Oct 30, 2007 | 08:55 AM
tony1's Avatar
What are you trying to do? lol
Old Oct 30, 2007 | 11:06 AM
Muckman's Avatar
Moderator in Chief
Default Re: Ignition Coil heat temp limit (tony1)
hehe Im trying to ask a very simple question because if I get into it then things get off topic. Have you ever measured engine bay temps in customers' cars?
Basically I fried 2 coils over the weekend from too much heat. I have a temp sensor mounted next to my distributor and engine bay temps were 275*F during highway cruising. Obviously that is too much. I am going to ceramic coat my manifold and a few other tricks to keep the heat down. But I wanted to know what my goal should be. If say 250*F was the known safe limit for coils that would be my goal. Otherwise Im left to trial and error (frying coils).
Old Oct 30, 2007 | 11:34 AM
tony1's Avatar
I don't think anybody can say what the "safe" temp is, but i've never seen a honda coil failure due to underhood temps. What computer are you running?
Garage 808 Hatch
Oct 26, 2010 04:53 AM
Nerologic
Jan 29, 2007 03:56 PM
crxhybrid1320
May 9, 2004 07:34 PM
CheezeFrog
Jul 16, 2003 10:23 AM
HyperREV
Jun 5, 2002 05:35 PM
