Ignition break-up while going into high boost pressure
Old Apr 4, 2017 | 08:46 AM
carlos8's Avatar
Default Ignition break-up while going into high boost pressure
Hi, My ls/vtec turbo, start to breaking on high boost suddenly. The weird thing is only on rolls, from the hole it make the full pass. When i try to make a pull from 3rd as soon it reach high boost it fall on his face, sometimes kick in again others i need to stop. The car is a relic from 2010, but it works fine for daily drive.
I'm guessing MAP sensor problems as the wideband goes blank when this happen. My laptop is out of commission but anyways (dataloging) on this software isn't effective.
Ls Vtec Piston & Rod 9.0:1
Crome Pro
650cc injectors
Omni 3 bar
No CEL on idle or in the moment of the issue
Old Apr 4, 2017 | 12:41 PM
motoxxxman's Avatar
Default re: Ignition break-up while going into high boost pressure
replace the cap and rotor, replace the plug wires with NGK wires, and put new NGK plugs in gapped to around 0.025". actual recommended gap size and heat range for the plugs largely depends on your power level
Old Apr 4, 2017 | 01:41 PM
carlos8's Avatar
Cap and rotor are new OEM, Cables have a few months (NGK blue) when the car start with the bug. My plugs always are at 0.024" BKr7e-11. The only thing i can recall is the coil been auto parts no brand.
Old Apr 4, 2017 | 02:01 PM
TheShodan's Avatar
Moderator
That's more than likely the case. Coil needs to be replaced. Try an Accel Unit. Under $50.
I love how you young people call 2010 a "relic". B-series honda turbos essentially haven't changed since about 2001. Just the software use, Injector size and type, and other fuels. The rest hasn't changed.
Talking to someone with 600whp+ capable and usable since 2003.
Old Apr 4, 2017 | 02:24 PM
carlos8's Avatar
great, see one on ebay Accel super coil HEI for $59.96
I'm not that young 42, but never had a engine with 400+ lasting this long, mostly i owned Rotary's.
Old Apr 4, 2017 | 03:57 PM
TheShodan's Avatar
Moderator
Neither am I. (almost your age...)
I've had a few Rotories last a long time, w/ Power FC at over 500whp. But we never pushed the limits like you guys in PR.
You don't even have to go eBay. (which I never fully trusted) They're even less a Summit Racing or Holley with full return warranty.
https://www.holley.com/products/igni...ls/parts/11076
Old Apr 5, 2017 | 04:58 AM
LightningTeg's Avatar
Community Builder
Default Re: Ignition break-up while going into high boost pressure
You can get those Accel coils at O'reillys
Old Apr 5, 2017 | 08:40 AM
dual_turbo30's Avatar
you need a MSD ingnition unit, it takes power directly from battery and gives it to the distributor.
they like 320$ for the control unit, rotor and cap . Mine didnt boost past 16psi until i got one and when it did it farted or missed spark or whatever its called.
Old Apr 5, 2017 | 09:48 AM
pumkinvineyard's Avatar
hmm
Old Apr 5, 2017 | 11:24 AM
motoxxxman's Avatar
lol, you should probably learn a bit more about ignition systems. not only is that information wrong, it's also somewhat bad advice
Old Apr 6, 2017 | 09:05 PM
carlos8's Avatar
Shodan, Bought the accel coil. While wait for shipping, i decide to clean and check the dist. OEM TD-87U. When open it, saw the CYP and remember i swapped it with a generic one from a china dist. Still on specs 404ohms (350-700 specs). Now that i'm working on this issue is recommendable to install a OEM one?
Old Apr 6, 2017 | 09:45 PM
TheShodan's Avatar
Moderator
OEM always seems to be best, but I admit, I've never had to change the CYP before.
Old Apr 7, 2017 | 04:03 AM
motoxxxman's Avatar
also while you're waiting, clean and tighten all grounds. and double check the main engine ground, make sure it's not starting to break apart anywhere.
disconnect the battery negative, do a resistance test between the battery terminal on the cable and anywhere on the chassis, and another resistance test between chassis and engine. if it seems high, test resistance of the cable itself between all 3 terminals on it (battery/chassis/engine)
Old Apr 7, 2017 | 08:20 AM
carlos8's Avatar
Ok, To prevent further headache i'm going to install a OEM one.
Jimster480
24
Jun 21, 2010 08:28 PM
frogg5872
May 27, 2010 10:20 PM
B00STED Si
Aug 19, 2005 05:08 AM
torr
Aug 29, 2004 01:06 PM
