if i get 84mm wisecos for my sleeved b18 will compression be similar
Old 03-02-2007, 08:56 AM
.adam.'s Avatar
Default if i get 84mm wisecos for my sleeved b18 will compression be similar
i want to get 84mm pistons for my sleeved gsr motor, but wiseco doesnt offer any under their "b18c1" section, so i was wondering if i could just use their "crvtec" pistons because they are 84mm. wiseco sells 84mm pistons for crvtecs that are good for a 8.4-8.8 compression ratio. will the ratio be the same on a gsr motor with a gsr head?
Old 03-02-2007, 10:28 AM
b18sihatch's Avatar
Default Re: if i get 84mm wisecos for my sleeved b18 will compression be similar (civicskater)
compression ratio will be determined by the dome CC of the pistons, what the exactcompresion ratio of the piston is right off the bat.
the compression ratio should be raised by the gsr head combustion chamber, and headgasket will also determine the compression ratio..
might be a little more might be a little less.
what kinda whp are you lookking to make
Old 03-02-2007, 03:39 PM
.adam.'s Avatar
well i already made 400 whp on 93 with my gt3076r, 81.5 wisecos, and eagle rods, so now im basically looking to max the turbo outwith a sleeved 2.0 setup. will getting the 8.4-8.8 compression pistons at least keep me in that range or would it be wayyy off
dc2-millano-red
14
01-01-2014 05:48 AM
VVENOM800TT
02-17-2011 02:48 PM
stealth50k
07-06-2008 01:13 AM
Nextelbuddy
05-09-2005 07:42 PM
blind
08-06-2001 10:43 AM
Quick Reply: if i get 84mm wisecos for my sleeved b18 will compression be similar
