idle drops
my idle gets lower and lower the longer i drive. when i turn it on it sounds fine and idles perect at 1000rpm's. what could it be? will sometimes stall out coming to a stop
si with a simple turbo kit- tuned with hondata s200b
i've seen alot of boosted honda's do this, mostly those with the hondata system, including mine. when i finaly got around to fully tuning my s200b for fuel, Ing, cams, egt and fule psi, on a dyno, at wot, idle and at stedy state driving @ 2k, 3k, 4k ect...then it went away. so did 99dragsi's. talk to a reputeble hondata tuner in your area, he/she should be able to help you out. remember that you are trying to get alot of varaible's to work together and at the sametime. good luck.
B18C2_sedan
Aug 19, 2006 07:11 AM
