identify this connection please.
Old Sep 7, 2004 | 09:13 AM
twkdCD595's Avatar
Default identify this connection please.
I think this is a vacuum connection and should be routed accordingly but I am not sure anymore. can anyone identify this for sure? I think it is the fia control silinoid thingy.
EDITD: pic would not show
btw sorry for the size of the pic, I dont have a way to resize it right now. (and yeah I know my egt is not on number 3 runner, and I still need a shorter feed too.)
Modified by twkdCD595 at 12:45 PM 9/7/2004
Old Sep 7, 2004 | 09:43 AM
norcalcrx's Avatar
Default Re: identify this connection please. (twkdCD595)
All i see is the red X
Old Sep 7, 2004 | 09:45 AM
twkdCD595's Avatar
Default Re: identify this connection please. (norcalcrx)
damn.... well I will try just linking it then.
http://us.f1.yahoofs.com/bc/5b...hs2lI
please let me know if it still no working.
Modified by twkdCD595 at 1:26 PM 9/7/2004
Old Sep 7, 2004 | 01:13 PM
twkdCD595's Avatar
bump... like I said I think it is the fia control silinoid vavle or something... is the link messed up?
can this be pluged or does it need to be routed to vacuum... this line runs to the bottom nipple on the fia thing... the top nipple is routed back to intake mani vacuum.
I think this is my problem with the wastegate not holding the correct psi... cause it is not spiking.
EDIT: also this is a prime example of why you should mark things when you take them apart for decent periods of time.
Old Sep 7, 2004 | 04:19 PM
twkdCD595's Avatar
no dice huh?
is this an f series thing or what?
Old Sep 7, 2004 | 05:01 PM
twkdCD595's Avatar
not an f series thing I discovered and still dont know anything more?
https://honda-tech.com/zerothread?id=293373 (has a picture of the valve itself)
other threads but never any replies.
https://honda-tech.com/zerothread?id=833742
https://honda-tech.com/zerothread?id=587394
https://honda-tech.com/zerothread?id=837284
https://honda-tech.com/zerothread?id=279271
Old Sep 7, 2004 | 05:05 PM
wantboost's Avatar
Who is Mr Robot?
I'm not sure if it's the same thing but we have it on bikes. It is basically an air pump that injects air into the exhaust tract for emissions purposes.
Old Sep 7, 2004 | 06:55 PM
twkdCD595's Avatar
Default Re: identify this connection please. (wantboost)
so should I have both nipples on it connected to vacuum sources? or what?
VI Boost
Dec 13, 2009 12:42 PM
dubs97integ
Jul 21, 2009 10:05 PM
angel_i
May 24, 2009 09:54 AM
Troy
Mar 29, 2005 10:19 AM
WestEM1
Mar 24, 2005 05:40 PM
