Ideling problem with hondata??
Old Aug 13, 2002 | 10:25 PM
99EBPguy's Avatar
Default Ideling problem with hondata??
Well, Ever since ive been running my base map, sometimes my car will start to idle funney, and then all of a sudden it will die, so i have to crank it over and give it gas and then it runs fine. I have heard of some problems at cold start up, but this is when my car is warmed up. If its due to running to rich with the 440's, then im gettin it tuned this week. But as far as the TPS is, do u think it should be adjusted. Right now my TPS % is 49, and i heard it should be around 45. Any help would be great
Old Aug 13, 2002 | 10:30 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Ideling problem with hondata?? (99EBPguy)
sounds like you might need to adjust your fuel pressure or check your base map. Or just get it tuned.
art
Old Aug 13, 2002 | 10:39 PM
B20C5 Turbo's Avatar
New User
At idle, the TPS (%) should be 0 and TPS (V) should be 0.45~0.50. As long as those readings are fine, your tuner should be able to fix the rest. Good luck.
Old Aug 13, 2002 | 10:55 PM
Mase's Avatar
Default Re: Ideling problem with hondata?? (B20C5 Turbo)
hondata's website has some great articles about tuning, Id read up on those.
Old Aug 14, 2002 | 10:01 AM
99EBPguy's Avatar
Default Re: Ideling problem with hondata?? (CDooMe2)
Thanx guys, I really need to get it tuned, hopefully this week. I hope that takes care of it
Old Aug 14, 2002 | 10:04 AM
99EBPguy's Avatar
Oh yea, I remember rreading a long time ago about the Turbo Mafia. Ive been a member for a while, but just rescently started posting when i got went turbo. But for the first week I ran open Dp and wastegate dump. Wasnt that the requirements for being part of it, i dunno, I though I remembered something like that.....
Old Aug 14, 2002 | 10:07 AM
DSF's Avatar
DSF
The first rule of the TurboMafia is...don't ask to be part of the TurboMafia.
Old Aug 14, 2002 | 02:14 PM
01geeser's Avatar
New User
Default Re: Ideling problem with hondata?? (DSF)
my base map does that too but what more can you expect it is a BASE map. cold starts are fine but warm starts just suck. go get it tuned.
Old Aug 14, 2002 | 02:25 PM
abraunb16's Avatar
New User
Come on now expand this "Turbo Mafia". I ran open downpipe for mutiple weeks, 4 1/2 to be exact. Now I'm running a 3 inch straight pipe with side exit by the rear passenger tire. No cat or res! I'm crazy like that!
Old Aug 14, 2002 | 03:09 PM
Trigun's Avatar
Default Re: Ideling problem with hondata?? (abraunb16)
i also have the weird idle/hard-to-start problem with a warm car on a warm day but it shows up very rarely ... this is with a tuned hondata map.
Old Aug 14, 2002 | 04:42 PM
Ltech's Avatar
Did the cops say anything? It must be freaking loud. I;m crazy but not that crazy
Old Aug 14, 2002 | 06:08 PM
JMinSi2000's Avatar
Default Re: Ideling problem with hondata?? (Trigun)
Same here. When the car is cold, it starts. When the car is hot it starts. But if it sits outside for 1-3 hours and is just warm, I have to sit there and hold my revs up to about 3,000 for about 45 seconds, then it idles.
bks84
16
Mar 7, 2012 07:59 PM
1baddcivicsi
Sep 19, 2009 08:09 AM
s2kkid
Sep 24, 2005 11:37 AM
Kidd_Stylez
Mar 17, 2004 09:10 PM
newt2
Jul 31, 2002 04:01 AM
