ID 2000s made by Bosch?
Old Oct 10, 2009 | 08:20 AM
  #26
96 GSR-T's Avatar
Default Re: ID 2000s made by Bosch?
Very nice, are you sure about the duty cycle? 650hp with 25% duty is almost 2000hp at 75% duty (assuming the flow is linear) that cant be right.... not with Corn.
I wish I had E98 locally I would be all over that ish
Old Oct 10, 2009 | 10:27 AM
  #27
Ovrbst_T66's Avatar
In aem datalogs it peeks at 23% and on ectune datalogs it shows 30%.Static fuel pressure is at 43 psi.
Old Oct 17, 2009 | 04:31 AM
  #28
karmadhi's Avatar
Looking to get ID1000cc injectors, although I have read of some users having problems with these injectors during hot starts. They suspect vapor lock inside injector.
Can someone shed some light on this issue?
http://forums.evolutionm.net/evo-eng...ors-evo-8.html
http://forums.evolutionm.net/ecuflas...latency-4.html
Old Oct 18, 2009 | 03:43 PM
  #29
tony1's Avatar
The 'hot start issue' is not injector related, it's car/ecu related. The cars that randomly have those problems are on stock ecu/reflash stuff where there is very limited control over cranking/cold start/etc.
Old Oct 19, 2009 | 04:06 PM
  #30
shady1375's Avatar
i switched from 1600 injectors to these 2000 injectors and there are worlds of difference!!!! only problem we are running into is if you are running q16 they are only good for up to 800hp on c16 they are good to 1000hp.... why i dont know.... they are telling me it has something to do with the plastic on the inside of the injector restricts the flow because of the oxygenated fuel..... but i still love these things!!!
Old Oct 19, 2009 | 04:20 PM
  #31
karmadhi's Avatar
what setup and what idle afr are you seeing?
Looking to get these to run on corn, evo guys are running over 800whp on corn with these!
I was using 880cc delphis and had somewhat choppy iddle at 13.8-14.5 afr bouncing at 1000rpm, any lower the car would hunt badly. This was on pump fuel.
Ok just saw the vid above answered my question somewhat, 13afr at idle not bad. We want something between 1000cc x 2000cc now T1! Any plans on a 1500cc injector? I would assume this is a special order injector from Bosch?
Old Nov 10, 2009 | 11:40 AM
  #32
TravSi's Avatar
but there are a few of these cars that are not having the problem on that same ecu platform with minimal-to-no tuning to the start-up fueling tables.
Also the complete start-up fueling routine has been found in the evo rom and there is 100% control over the start-up fueling which has not even made a slight difference in the warm start-up issues.
Old Nov 10, 2009 | 11:43 AM
  #33
tony1's Avatar
There have also been guys that have swapped injectors from cars that started fine and cars that didn't and the problem stuck with the car, not the injectors.
Manny1987
Engine Management and Tuning
Dec 22, 2009 07:44 AM
Black R
Aug 7, 2004 08:01 AM
1.8t
Oct 26, 2003 07:32 PM
TurboJesse
Jun 29, 2003 04:31 PM
zojirushi
Feb 13, 2002 06:26 PM
