I want to see.....
Old Jun 22, 2002 | 10:11 AM
HXMan's Avatar
Default I want to see.....
...some pics of oil feed lines, with T's away from the block, and espically if you have an oil pressure gauge as well.. I have my T away from my block...but it seem pretty ghetto, and is leaking.
I want to add an oil pressure gauge, but the only Earls T's I can find take a -6an feed.......post some pics up with part descriptions to help me out.
Thanks!
Old Jun 22, 2002 | 10:15 AM
93LSivic's Avatar
Default Re: I want to see..... (HXMan)
If your going with a pressure gauge just lose the factory pressure sensor. No need for it.
Old Jun 22, 2002 | 10:18 AM
HXMan's Avatar
Default Re: I want to see..... (93LSivic)
I know, but my whole feed system need to be revamped anyway....my oil leak is coming out where the factory sensor threads in. I have taken it out twice and reassebled it, but it still leaks.
I was dumb and only ran the T 8" away from the block. It is a pain in the a$$ to work on there.....
Old Jun 22, 2002 | 11:07 AM
93LSivic's Avatar
Hmm, I did the same thing and it leaks slightly. Its because its the BSPT or whatever and I used a NPT fitting. Im kinda scared to take it out or move it around cause it'll probably just get worse.
Guess you need to lengthen that T up the firewall and go from there. But you still wont need the factory oil pressure sensor.
Old Jun 22, 2002 | 11:17 AM
HXMan's Avatar
Well....even though I am between jobs right now( ) I ordered some parts from summit that will fix this. I don't have an oil pressure guage right now, so I am just going to run the line with no pressure warning guages for a couple days. I need to go to the drag strip next weekend( I can't be leaking anything), and I haven't figured out what type of oil press gauge I want, or where to put it.
EAR-100192 Earls Pressure Guage adaptor -6an male ends $8.50 (1)
EAR-300104 Earls Auto Fit hose ends -4an $5.95 (4)
EAR-306004 Earls -4an Auto Flex Hose 6ft $31.95
EAR-981604 Earls Straight 1/8 NPT male to -4an male $1.75 (1)
EAR-989464 Earls -4an male to -6an female $6.99 (2)
[Modified by HXMan, 2:17 PM 6/22/2002]
OGMatt
Aug 15, 2011 01:11 PM
danny_civic97
Mar 12, 2007 01:00 PM
itsJDMyo
Feb 21, 2006 11:36 AM
turbotime
Nov 29, 2003 04:58 PM
jisecup
Nov 19, 2003 10:00 PM
