i need a new fuel pump.......
Old Feb 16, 2006 | 06:46 PM
buttsneeze's Avatar
Default i need a new fuel pump.......
well, actually it's my friend who needs the fuel pump. What i need to know is can he go ahead and install an aftermarket high volume one even though it's not needed yet? Here's the detail: right now it's an n/a h22a, but he KNOWS he will be going turbo in the next few months......so this part will have to be replaced anyways.
He needs a new one regardless, it must be changed now, but instead of putting another factory replacement..........is it ok to go ahead and run the high volume? Will it hurt anything to use it on the all motor setup in the meantime?
Modified by buttsneeze at 3:53 AM 2/17/2006
Old Feb 17, 2006 | 02:55 AM
buttsneeze's Avatar
Default Re: i need a new fuel pump....... (buttsneeze)
ttt
Old Feb 17, 2006 | 03:22 PM
buttsneeze's Avatar
bump........
Old Feb 18, 2006 | 03:12 AM
buttsneeze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buttsneeze &raquo;</TD></TR><TR><TD CLASS="quote">well, actually it's my friend who needs the fuel pump. What i need to know is can he go ahead and install an aftermarket high volume one even though it's not needed yet? Here's the detail: right now it's an n/a h22a, but he KNOWS he will be going turbo in the next few months......so this part will have to be replaced anyways.
He needs a new one regardless, it must be changed now, but instead of putting another factory replacement..........is it ok to go ahead and run the high volume? Will it hurt anything to use it on the all motor setup in the meantime?</TD></TR></TABLE>
anybody?
Old Feb 18, 2006 | 04:07 AM
boostedcivicsir's Avatar
Mr. Badwrench
walbro 255 hp will be the pump you need, keep the stock reg on it and you will be fine.
Old Feb 18, 2006 | 02:00 PM
buttsneeze's Avatar
Default Re: i need a new fuel pump....... (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">walbro 255 hp will be the pump you need, keep the stock reg on it and you will be fine.</TD></TR></TABLE>
so as long as we keep the stock fuel pressure, then we can go ahead and put on the 255 hp fuel pump, even though we won't be putting the turbo on for a few months from now?
Old Feb 18, 2006 | 05:29 PM
Mr. Badwrench
should be fine
i ran a 255 hp with an aeromotive a/a till i got through the state sniff test
Old Feb 18, 2006 | 07:57 PM
locash's Avatar
The Walbro 255lph HP will raise the fuel pressure and make the car run pig rich. Be prepared to compensate for this. Other than that, go for it..
Old Feb 18, 2006 | 09:08 PM
buttsneeze's Avatar
Default Re: i need a new fuel pump....... (locash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locash &raquo;</TD></TR><TR><TD CLASS="quote">The Walbro 255lph HP will raise the fuel pressure and make the car run pig rich. Be prepared to compensate for this. Other than that, go for it..
maybe then he could advance the timing a degree or two to compensate.......
Old Feb 19, 2006 | 05:54 AM
B6tPoweredMx3's Avatar
explain on how a fuel pump will raise the fuel pressure?
Thats why you have a fuel pressure regulator.
Keep the fuel pressure stock and install the pump.
Old Feb 19, 2006 | 06:03 AM
93supercoupe's Avatar
Default Re: i need a new fuel pump....... (B6tPoweredMx3)
when I installed my 255 w/ the stock regulator it jumped, I had to turn it down with my adj FR.
Old Feb 19, 2006 | 02:27 PM
buttsneeze's Avatar
Default Re: i need a new fuel pump....... (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">when I installed my 255 w/ the stock regulator it jumped, I had to turn it down with my adj FR. </TD></TR></TABLE>
he will still have the stock regulator, though.....so he won't be able to adjust fuel pressure
hondaaccord94
Dec 30, 2006 10:14 PM
k-series
Sep 10, 2006 10:01 AM
tr0n9h
Oct 4, 2005 06:40 PM
tweekerz
Jul 25, 2005 05:15 AM
mdj_ge
Jul 7, 2004 04:08 PM
