I need to know.........
Old Apr 18, 2002 | 05:45 AM
TurbodCX's Avatar
Default I need to know.........
does anyone know if the 88-91 zc dohc head will fit on to a d seriers block?? i have heard that the bolt pattern for the two is the same, but would like to know....
i know i will need another timing belt and all that stuff........
thanks
brian
Old Apr 18, 2002 | 06:52 AM
TurbodCX's Avatar
Default Re: I need to know......... (TurbodCX)
no one knows????
Old Apr 18, 2002 | 07:22 AM
TurbodCX's Avatar
damn 20 veiws and no one knows?? please i need some help here.
help out a fellow h-t member
Old Apr 18, 2002 | 09:25 AM
AutoboTxEK's Avatar
i have no idea...however..I did ear from a teammate of mines..saying you can put a B series head on a ZC...
Old Apr 18, 2002 | 09:36 AM
sgT's Avatar
sgT
Default Re: I need to know......... (AutoboTxEK)
Doubt that since the head gaskets are not the same.
The ZC and D-series head gaskets are the same, so logic would assume that
its possible.
Old Apr 18, 2002 | 09:40 AM
TurbodCX's Avatar
Default Re: I need to know......... (sgT)
Hey sgt, are you sure that they are the same??? i thought that they were also that is why i need to know for sure though...........i really need a promising answer.
and just a maybe, so if you are sure then let me know...
thanks
Old Apr 18, 2002 | 10:39 AM
Sonny's Avatar
Any SOHC D series block will not accept a DOHC D series/ZC DOHC head without some work. The hole for the bolt near the the #1 cylinder is moved slightly. It will require some modification to the head or block as well as the headgasket.
I tried putting a D16A6/Y8/Z6 head onto a D16A1 (86-89 Integra DOHC) and I ran into this problem. I decided to stick with the DOHC Integra head.
Sonny
chris riz
12
Sep 22, 2011 12:34 PM
EJ1B18c
Apr 26, 2008 02:04 PM
HybridB18Vtec
21
May 10, 2006 05:11 PM
zerostyle
Jul 24, 2005 08:29 PM
Hybrid
12
Mar 11, 2002 07:35 PM
