I need fuel lines
Old Oct 25, 2003 | 12:36 AM
R-1303's Avatar
Default I need fuel lines
Looking for this setup off my fuel filter to my fuel rail.....my buddy sent me this pic...who was it that sells them again?? I remember he is a respected member of this board....and sells the kits.
setup for: b18c5 stock fuel filter and rail.
Old Oct 25, 2003 | 12:38 AM
Foozball26's Avatar
Default Re: I need fuel lines (R-1303)
we only act like we respect Flameno-T
hes the man for all your plumbing and milf hunting needs
after all he was masterbating at the age of 9 when all his girlfriends were being born lol <---had to be there
Old Oct 25, 2003 | 12:59 AM
R-1303's Avatar
Default Re: I need fuel lines (Foozball26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">we only act like we respect Flameno-T
after all he was masterbating at the age of 9 when all his girlfriends were being born lol &lt;---had to be there</TD></TR></TABLE>
alright...i don't care what the man does with his free time....as long as i get my product, oh yeah flameno-t wear gloves when i buy stuff eh!
whats his name??
Old Oct 25, 2003 | 01:03 AM
Arturbo's Avatar
Better than steak
25 Year Member
His name is Stan (flamenco-t).
Old Oct 25, 2003 | 01:06 AM
Foozball26's Avatar
Default Re: I need fuel lines (Arturbo)
Yup hes a good guy and seller
Old Oct 25, 2003 | 01:10 AM
R-1303's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">His name is Stan (flamenco-t). </TD></TR></TABLE>
Thanks, i'll be sending him a pm...also would you guys recommend a fuel pressure gauge on top of the filter?? or can a guage be put somewhere else to read fuel pressure.
Old Oct 25, 2003 | 01:15 AM
ATS*Mark's Avatar
OG triple OG
yep hes the man for all ur goodridge needs
Old Oct 25, 2003 | 01:13 PM
R-1303's Avatar
Default Re: I need fuel lines (TURSpoonEK)
how do i remove the stock fuel lines??? and any special way so i don't spill fuel everywhere??
Old Oct 25, 2003 | 02:35 PM
Foozball26's Avatar
disconnect the battery so you don't accidently ground something out and spark.
and just get a rag to catch any spilling. Its not gonna be pressurized so you'll just have a little bit a spillage
Old Oct 26, 2003 | 10:13 PM
R-1303's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">disconnect the battery so you don't accidently ground something out and spark.
and just get a rag to catch any spilling. Its not gonna be pressurized so you'll just have a little bit a spillage</TD></TR></TABLE>
after removing the fuel lines...the fittings should go on like stock??, also will any sealant be needed??
Old Oct 26, 2003 | 11:24 PM
Foozball26's Avatar
yes, the fittings stan sells go on like stock.
you may want some teflon tape on the threads that go onto the fuel filter and rail.
but you don't need them for the fitting to fitting connections since they are self sealing.
stan (flamenco-t) will tell you everything you need to know for the install, its pretty straightforward.
Old Oct 26, 2003 | 11:50 PM
Mr. Softee's Avatar
i made a big thread about how to install these. search back
sam
Old Oct 27, 2003 | 12:17 AM
R-1303's Avatar
Default Re: I need fuel lines (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">i made a big thread about how to install these. search back
sam</TD></TR></TABLE>
read the thread..good info!..so the setup i buy from stan, already comes machined right?? I will be using the stock Itr fuel rail
question: you think an after market fuel real in really necessary?? or more for bling factor?...horse power goal for me is pretty conservative of 300-320 whp.
Old Oct 27, 2003 | 12:52 AM
Mr. Softee's Avatar
100% not needed. same goes with the lines.
Old Oct 27, 2003 | 12:23 PM
R-1303's Avatar
can somebody give me a phone# to call or a web-site for the flamenco??
Also...everything should just bolt right on correct? or will i have to do some re-threading on the fuel rail or filter?
Thanks, Mark
Old Oct 27, 2003 | 01:37 PM
mamaboy's Avatar
Stan I think we should really start working on your site. Art's and Earl's as well. I always see hundreds of posts for benson, pwr, oil lines, fuel lines, and precision.....guys send me information so i can start brainstorming
Old Oct 27, 2003 | 02:50 PM
AVATAR's Avatar
Default Re: I need fuel lines (mamaboy)
Shoot him an IM https://honda-tech.com/zero...=5619
Old Oct 27, 2003 | 03:17 PM
Flamenco-T's Avatar
Default Re: I need fuel lines (AVATAR)
thanks guys,
R1303, I have all kits in stock for any kind of fuel rail including stock. On stock rail I use the aluminum anodized banjo fitting to fit the stock stud on the fuel rail and it will connect to a -6AN hose end. The banjo fitting looks like this,
the hoel will slide over your existing stud that sticks out of your stock fuel rail, then the -6AN hose end wil thread into the threaded area.
No machining needed at all, All kits will be assembled and tested, all you need to do is remove the stock line with 17mm wrench and the fuel rail fitting with an adjustable wrench. It will takes about 15 minutes tops.
stan
Old Oct 27, 2003 | 03:38 PM
Mr. Softee's Avatar
Default Re: I need fuel lines (Flamenco-T)
stan i want to make to u
Old Oct 27, 2003 | 03:49 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">stan i want to make to u</TD></TR></TABLE>
oooh hellllll noooo
stan
eg:R
Mar 31, 2010 05:37 PM
JohnnyM
Aug 3, 2009 09:13 PM
CivicHB89
Jan 4, 2005 05:18 PM
jaycapz
Sep 23, 2004 09:23 AM
ATS*Mark
Nov 5, 2003 08:29 AM
