i need everybodies help on this one!!!!
Old Nov 10, 2001 | 09:07 PM
91lude's Avatar
Default i need everybodies help on this one!!!!
i had the top end built up to run turbo(bigger valves,turbo cam,port work and bigger fuel pump) car ran great on stock bottom end till it blew up.
now,i did 9:1 piston and rods i broke the engine in without the turbo. but now it seems that the engine wont rev past 4500rpm.
do you guys think the reason might be cause i have the head setup of turbo use and have no turbo hooked up to it yet and thats why its not reving past that4500 rpm.
i really need your info or any ideas on this before i junk the dam car!!!!!!!!!!!!!!
Old Nov 10, 2001 | 10:43 PM
Smashback's Avatar
Default Re: i need everybodies help on this one!!!! (91lude)
Don't think so, it should probably just be a slug on the low end if you have big valves and ports though..running w/o turbo that is
Old Nov 11, 2001 | 10:24 AM
Jared's Avatar
Depends on how you mean "wont rev past 4500" does it rev limit? what?
GARRETTI
Jul 21, 2008 01:29 PM
escape2me
Apr 20, 2004 12:49 PM
scramblerman
Mar 8, 2004 05:01 PM
tonezilla
Feb 23, 2004 11:34 PM
91lude
Nov 9, 2001 09:25 PM
