I need a base map to get to a tuner!
Old Jun 2, 2009 | 05:03 PM
1DayIllBFast's Avatar
Default I need a base map to get to a tuner!
My setup will be a 96 civic with B18C with Hondata s300, peakboost FTW series kit, with 660cc injectors. Does anyone have a base map for this setup or know where i can get one? also how do i install the base map into my EC/hondata? or will i be fine with just installing everything and driving 20 mins to the tuner without going into boost?
Old Jun 2, 2009 | 05:19 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: I need a base map to get to a tuner!
go to hondata.com
Old Jun 2, 2009 | 05:23 PM
i have been there plenty of times but just can not seem to find any info
Old Jun 2, 2009 | 05:31 PM
smoovy's Avatar
best bet is to find someone that can tow you there if it's not too far or you can do a lil tweaking of your S300 and get it to idle to check for leaks and stuff like that before you get tuned. then get it towed there...
Old Jun 2, 2009 | 05:34 PM
smoovy's Avatar
here it is
Old Jun 2, 2009 | 05:36 PM
couldnt i just install everything besides the s300 and injectors drive it there granny shifting not going into boost and then install the s300 and injectors there? Its about a 15 minute drive on straigh roads. or would it just be best to install everything then get it towed?
Old Jun 2, 2009 | 05:43 PM
smoovy's Avatar
really it's up to you. I feel comfortable enough to make a basemap and drive to where I need to go, but if you have no clue what your doing or not comfortable then just remove the wastegate spring and drive it there and install your goodies. or get it towed. to me personally, it doesn't sound like your too comfortable to do either, So I say get it towed. better safe than sorry.
Old Jun 2, 2009 | 05:48 PM
yeah i would feel much better if i could find a good base map for my setup. if not i will just get it towed i guess. Also just a question one of my friends mentioned but i didnt know if it is possible or would work. But he was wondering if i could use his base map but he has a B16 with 440cc's not the same turbo kit either but its still turbo. Can i use it or no. Do i need an exact base map or something relativly close? and thanks for that link man!!!
Old Jun 2, 2009 | 08:02 PM
smoovy's Avatar
NO, not the same size injectors. not going to work
Old Jun 2, 2009 | 09:56 PM
mtber's Avatar
Contact the vendor you bought the system from, they maybe able to provide you with one.
We provide our customer's with a free calibration with the purchase of their system.
Dakota
Feb 4, 2009 01:20 PM
timisyourfriend
10
Jan 6, 2006 07:31 AM
turbo89civicb18hatch
Apr 12, 2004 09:54 AM
queez
Dec 27, 2003 07:24 AM
dabrown
Jul 30, 2003 06:08 AM
